Hi guys.
So, i have the chace to buy the DT990 600ohm + fiio k5 pro to used them 95% of the time for fps gaming and 5% for media consumption.
Also i have the chance to get 2nd hand AKG Q701 QuincyJones + HeedCan amp.
What do you guys thinks is best for gaming? Heedcan amp is any good? Do i need a dac with it?
Or get the dt990?
The DT880 600 is prob still top dog at the price point for FPS audio. But, the 990 is gonna be damn close and give more bass impact, if that’s what you want. If you’re getting good deals, I see no reason to hesitate. I can’t speak to the AKG, though. I have 0 experience with it.
@ShokZ Is this why you were asking me about the tygr? Just now saw this post. DT 990s for competitive 880s for inbetween casual and competitive 58x for more color and warmth for all around but with less sound stage. Ad700x for brighter colored but wide sound stage yet real cheap actually shockingly good for competitive despite its price and superceded by 1000x which adds complete seperation of sound. I will let you know what I think later when I get the Tygr. Always go 600 ohm for dt if you can, sounds better. K5 pro may struggle a bit on the 600 ohms suggested switching to liquid spark or magni as we mentioned earlier.
@Falenkor thanks man. I’ll just stop asking myself “what about this headphone or this headphone” and just buy dt990 600ohm… i found my gaming gaming headphone. Now i just need to figure wich dac amp to get.
there are some cheap options but I stick with Topping. Been using a d10 which is nice. Upgrading it to an E30 which is like $40 more. Still an upgrade.
@Falenkor@RiceGuru@M0N guys i was searching for amp/dac and found this at a reasonable price… do you guys know anything about sabaj d4?
Schiit magni 3+ are very dificult to get right now due to stock isues…
Thanks
So for the beyers, that’s not going to be ideal as well, the single ended output on it is not good, and you can’t run the beyers balanced unfortunately. You could grab something like a topping a30 if you can’t get the a50, or perhaps a bellari HA543 but that one would be hard to get outside of the us I would guess, same as the archel 2.5 pro I think.
Lol k. I think you will like it though especially if your a hardened competitive player… it through me through a loop quite a bit after I got my setup. Magni 3+ should be fine if you cant obtain the liquid spark.
@Falenkor@M0N guys i think i’ll be able to get a LĂquid Spark amp… But only in 1-2 months…
Should i wait or get the magni 3+ ASAP? One or the other Will be paired to topping d10.
