You’re very right about this. And I think that’s why I’m out of the budget market (except maybe a planar down the road). I had 4 sets in the under-4100 range that did everything I could’ve needed (T3+ my main set, KZ ZAS which was good for trying out BA set frequency responses that don’t play back well on 1DD’s, KZ DQ6 which turned out to be the only set I had that plays the Serial frequency and not sound garbage, and the CRA was my beater set that I lost a earpiece and didn’t want to murder something).
I’ve got all the flavors I can reasonably get at sub-$100, so while it’s fun to watch new things drop there’s no reason to buy any of it other than to play “Gotta Catch 'Em All”.
Agreed. That is the ideal scenario, but the mod’s difficulty is probably the same as tip rolling anyways (actually it’s probably easier :joy:). So if you already do that then I don’t see why not just do the mod as well. Literally takes 5 minutes.
Trust me I would also like a set where I don’t have to do anything, but considering the end-result the small effort is justifiably worth it. There’s no set around $150 that can compete with modded Olina :100:
Seek Real Airship being described as having the same driver as Olina but the better tuning out of the box (or “Olina but better tuned” if you wanted to go there), by multiple sources, would have something to say about that.
Now I can’t say one way or the other about which is better, as I’ve never heard them, but Airship can clearly compete with Olina. And it is one of the sets I’m thinking about on that upgrade path down the road.
Around $150 usually means <$150. I agree that the Airship is a great set, but you can save $70 (save $90 when it’s on sale) by taking 5 minutes and adding a filter? :man_shrugging: Just my 2 cents.
Does any one know a good and not very expensive short usb-c to usb-c cable that works with dongles/amps? The shorter I have is 30cm and Id like it shorter.
The Ddhifi one looks nice, but damn they are expensive.
Under $150 means <$150. Around $150 means both above and below. Just my 2 cents
Alright man :joy: Tip rolling is infinitely more annoying than adding an extra filter but whatever floats your boat :speedboat: You can grab a whole Mangird Tea on sale with that savings :man_shrugging: Or a hook-x.
Gotta say though the airship does look more sleek :sunglasses:
In a super-quick search that’s about the most reasonable thing I see. Mayhaps that could work?
I just don’t understand where you think you’re going to change my mind about how I want to spend my time/money. From the start, I said I do not want to do the mod, so why would I magically change my mind because you’re like “c’mon dude”?
Didn’t ask for your opinion, and try being a little more respectful next time. Thanks though, and take care
https://www.aliexpress.com/item/1005003280439978.html
13cm from the tip of each USB connector.
I’m just voicing my opinion like you? You can do what you want man I don’t care :joy: I thought we were just talking.
Anyways, good luck with your future IEM ventures my guy :+1:
Can’t find it on my amazon :frowning:
Do you own any of those? They gucci?
yes, 2. Ordered some wires and they sent me 2 usb-c to usb-c adapters lol. (they resent the wires and I get to keep the adapters.)
I dont have anything to use them on though, so cant comment on that. But the wire does feel sturdy and thick.
Only the purple is on sale, but the strain relief looks good.
I just ordered one of this (very cheap, will probably arrive next year):
And got rec’d one of these type, they seem to be more durable (getting from amazon, if it’s shit goes back):
If you don’t use it, just sell it to me next time you ship me something :smiley:
Haha, yeah np. I always forget to include the best shuoer iem whenever i ship to you. :smirk:
Hakugei USB-C to USB-C C$ 14.07 | Luck. Type-C to type-C Lightning to Typec DAC Cable convertor.
C$ 4.79 35%OFF | USB 4.0 Gen3 Data Cable PD 100W 5A Fast Charging USB C to Type C Cable Thunderbolt 3 4K@60Hz Cable USB Tipo C 40Gbps Data Cabel
15 day garanteed delivery (which means a week for me)?? Sold.
EDIT: nvm, shipping costs as much as the cable lol, just gonna get the amazon one
