Play with Balanced?
Current Gear List
-Schiit Lyr 3 with internal standard DAC
-Hifiman Sundara
-Grado 325e
Nothing is being ran balanced, but I’m curious if its worth it. I recently was gifted the Dekoni Blues T50RP mod and starting to wonder it would be beneficial to venture out for Balanced cables for the Sundara, and a balanced AMP/DAC, and maybe some balanced options in the future. The Lyr 3 has plenty of headroom, clean, and enjoyable… If the only advantage of balanced is more power, then maybe what’s the point?
Thanks in advance
There is not always a definitive yes/no answer, but check this out it may help you decide what is best for you.
Cheers!
Yeah there’s no reason to worry about running your headphones balanced until you have an amp with a balanced output that’s known to be superior to its SE out. IME, the difference is quite small, if noticeable, with most amps and headphones.
Don’t buy balanced gear just for the sake having it. Case in point, Asgard 3 vs Magnius.
Thanks for the clarification. The Lyr 3 is a great amp, and the question of not having the balanced output always made me wonder. Thanks again!!
