Gotta be careful when you hop aboard the hype train. Choo-choo! ![]()
also ordered this blue color ![]()
Nobody expected them to be⦠Folks buy them for the tuning ![]()
But the hype around these IEMs is a bit excessive ![]()
yeah I shouldāve asked for more blue and purple on the red faceplates instead of green and blue
noted, Iāll probably buy those since the pressureās really messin with me lol
I like to use mine for longer than 3 hours at a time so you get to really feel em after a while. Still not as bad as my XM4s tho
if I canāt find a good enough solution, I sadly will have to sell em
Let me know if they work for you!
There is also a balanced version, but I donāt have it.
will do, ended up grabbing the balanced version since I wanted a s/m/l pair even though Iāll probably be just fine with L lol
Other eartips recommended for pressure relief, but not tested by me:
Triple or double flange tips
COMPLY TZ-200
MoonDrop Spring Tips
Tanchjim T-APB T300
Iāll keep those in mind in case these arenāt great, Iām hoping theyāre great though, balanced arriving today and if they help my Pula Iām grabbing wide bores as well
Got mine yesterday, havenāt spent much time with it, but for the price itās clearly a great competitor. Thanks to Tone Deaf Monk for the recommendation, bought PA02 before the review ended (%
UPD: noticed funny resemblance:
Doesnāt get much closer than that. The PA 02 probably has more bottom note weight with the DD but tuning is wow
Okay these things are magic and definitely help out with the pressure but sadly I need a slightly wider one, will take a while but Iāll probably give the Moondrop XL spring tips a go as well at some point but for now these work well enough
Springtips will be better and give you more bass.
I am glad they helped with the pressure problem, even if it was not a final solution. I have a narrow ear canal and I think the Wide Bore tips are a little bigger than the Balanced ones and for me they work well but sonically not the best for this IEM.
Is it better to order Moondrop XL size for these headphones?
Iām hoping theyāre just as great as the sangcai with the ear pressure since the XL is like the perfect sizing and I remembered loving spring tips when I bought a set of Arias before
I grabbed the wide bore and XL pair from Linsoul since I could always just order a Chu from Amazon if I need smaller which I highly doubt Iād need
I do agree itās not the best sonically but I was able to wear em for so long and without issues so now I wonāt end up selling mine. Honestly great find
Let me know if wide bore and spring tips help with pressure relief and if they sound better! ![]()
FYI; if pressure relief via tips is needed, then foam tips will do better than silicone ones. Or you could consider the hybrid silicone/foam tips like the Sony EP-TC50.
Iāll give the hybrid ones a check since I didnāt know they made those, the foams are great but I dunno why but I feel icky wearing em for some reason.
Thanks for the rec, Iām gonna check em out
Well hopefully the spring tips are good enough because Iām up to my knees in tips now and I need somewhere store em now lol
