The Polk Audio PSW505 or Bic PL-200 II might be better for volume output, and have speaker level inputs (same thing as high level, just on the rel they have that fancy connector)
I should mention I’m not in the US, Polk is rare and not that well priced here(Romania). Can’t seem to find the 505 at all, found a PSW404 at ~350$
Klipsch is also more expensive that it should be.
Looking for stuff I could also maybe try before buying. The klipsch could be an option, it’s also around 350$
Availability and prices are really good for British and european brands. Really bad for US and Canadian brands. But I’m mostly interested in the Tzero for now, it’s pretty sexy, except not very big.
Loud enough to keep up with the Bronze 2 without turning into a fart machine. I’ve never owned a good sub so I don’t know if a 6.5" enough. Or if the Tzero is doing some magic with its size to make it work.
Probably not with -6dB at 38 Hz specs but it will give bass. Probably in the reasonable levels to go along with Bronze 2’s. Not really in loud region.
Aaaand it won’t do and go really low low frequencies (~20Hz). To me that one of jobs… No it’s requirement that a sub needs to do.
So i would save money and get something else later on.
Like the SVS PB1000, ±3 dB 19 Hz - 270 Hz and has high level Inputs and it’s a totally different animal. Deepest, most detailed and authoritative bass you can get for under $500 (american) so in the Romanian region that somewhere in the ~2800 ron (600$) region.
Or something else but would still save few more months or how long it takes.
Have heard so many low tier subs in the 500$ region and most just suck… they more like loud low-midrange speakers with no low end.
