The FH3 is kinda strange since volume matching at 1khz looks really weird.
But works with 500hz
To change where the graphs are volume matched at, just change the value here:
Well, you can see that the FH3 has quite the bass elevation whule the treble isnt as much. So thats a sign of it being L or bass-boosted neutral.
Ah it’s matched at 1kHZ, I thought it would match on the mean of the FR (like I said, no knowledge of this stuff :P). Thanks!
If you dont have much knowledge about graphs, its better to ignore them I believe.
Although graphs like these dont really need much knowledge to tell if its bad or not lol:
Yeah I don’t let them influence my purchasing decision, however I do look at them to compare stuff I know so that I will learn to get some information about them in the future.
The Kinera Freya kinda scares me as well lol.
That is wise
btw, do we have any gamers here? Anyone playing Wow tbc prepatch?
Congrats on the cool kid club membership. Do you know which IEM is closest to your target? Your bass level is up there
Solid dude
Indeed, he´s already helped a lot of others with the database site.
Final Audio E1000 (micropore mod) VS Blon BL-03 (mesh mod):
Setup: Schiit Asgard 3, Radius deep mount tips on both iems
Bass: extends a bit lower on the 03 but rumbles more on the E1000 and has more sub-bass quantity on it. But cleaner on the 03 because it is a bit tighter and faster and is more textured as well. More mid-bass quantity on the E1000 but better quality on the 03 due to the faster and tighter bass, similar texture.
Mids: Female vocals have a bit better tonality and timbre on the 03 but is more forward on the E1000. Male vocals have a bit better tonality on the E1000 but better timbre on the 03 while quantity is similar.
Treble: cleaner and more detailed as well as better timbre on the 03 and also extends a bit higher. The E1000 is more relaxing and non-fatiguing though.
Technicalities: A bit wider soundstage on the 03 but similar depth. Details, instrument separation and imaging are better on the 03 but similar imaging. The 03 also got better resolution than the E1000.
Overall: The 03 is above the E1000 in sound and it is also more power efficient. The E1000 wins in the fit department though, as the 03 is more likely to be a problem for most people. So, if you already got the 03 and it fits you, the E1000 is most likely a downgrade, unless you want something even warmer than the 03. If you don’t have any of these 2, then the E1000 is the easier recommendation since it Is more likely to fit you than the 03 and you can go from a warm-neutral tonality to a bass-boosted neutral tonality using the micropore mod (which is fully reversible and easy to do).
(here you go @Strifeff7 )
Just a quick guestion guys…
a 34mW into 32 Ohms is like an average phone output?
right?
Thats great, I am just looking for a headphone guitar amp.
This means regular IEMs and sensitive headphones should be alright, I guess.
It shouldnt be a volume problem, although the quality might not be very good. Especially since I am not sure if guitar amps have high impedance.
Well, the combo I got has like abysmal hp/emulated out output, but this one should be headphone oriented, so I hope it will be just fine…
Not familiar with guitar amps so I cant really help you there.
Well, as far as I am concerned, the best solution for “hifi” monitoring would probably be to run the guitar cable straight to audio interface, then process it digitally in your PC and output it to an external dac…
But yeah, money is a real thing and I am not a millionaire
