And there’s white noise on the right ear… FML.
Any guess why this happens?
Swap the L/R to see if its the cable.
It is. Swapped and noise went to the left
Sounds like a cable issue then…
2021-08-03: Yincrow RW-100:
Rank: C
L-shaped, bloated bass and warm tonality that isn’t very well-tuned. Tech is pretty meh as well. I don’t see the reason to get this unless MX500 shell just doesn’t work for you, otherwise most MX500 buds are a lot better than this and the X6 is just…. outclassing it a lot.
Fit is more like an iem without the tips and comfort is good at the beginning but gets very uncomfortable after a while.
I’ve been reading reviews on good all-BA sets like Dunu SA6, BGVP DM7, etc. Some reviews from you also. It seems unlikely that even double bass BA will slam.
GD3A, if anything, taught me that in my book, there is no saving grace for kickdrums that don’t kick ass. So I will pass on 300usd ST6A or B.
I will check your next reviews, as I assume GD3A will be part of your comparisons in the future.
Thanks
Yeah, I dont really think BA´s can compete with DD´s usually. But the sonion BA´s they are using are actually vented BAs and the DDs they are using are kinda similar to BAs. So the difference might not be very big between them.
More mid-bass will help with those genres though, which the ST6A seems to have over the GD3A.
Yeah, GD3A is going to be one of those iems that will show up in my comparison section a lot. (unless the iem I am reviewing is so different it becomes an apple/oranges comparison.)
@Grolik Thank you for your support! (patreon)
You buy stuff so that I don’t have to. That’s the very least I can do. Looking forward to your next recommendations…
Appreciate it.
Next few reviews will be buds and a headphone though.
That’s okay you do your thing. DQ6 will do fine. GD3A for Scorpions and so on. They’re really great.
Consider trying earbuds though. They are great and a fresh of new air from iems. :+1:
(also extremely affordable, since the value is in the 0-20 usd range.)
Try XINHS on AliExpress
Yeah I love Yincrow X6 but they tend to fall off my ears. I’ve tried double foam (full + donut) and some rubber “tyres” around the bud but the sound takes a hit.
oof, guess MX500 might not fit you as good then.
Check out the K´s LBBS (Bell-LBS), that might fit you better.
@Grolik This one: Temperament (Ksearphone) Bell LB/Bell LBs 3.5mm Bass HIFI Metal Earphone 15mm Dynamic Driver Unit Earbud Headset Flat Earplugs|Earphones & Headphones| - AliExpress
Bell-LBS, not the none-S version.
Very small shell and comfort/fit is great.
Okay it’s got my vote then :wink:
It is. Already talked to Xinhs, hes making another just like that and sending it asap. Its a bummer, but the materials are very very good and the braid is slim.
Good support from him. Would be a pain if he told you to submit a video proof or something like that.
No company would ever be so petty as to do that… especially if it was not a custom cable but a not that expensive cable on Ali or something.
