Yes, you will want to choose 2.5 mm jack I suppose.
And customisation possibilities seem large, he will make me a short jack-to-jack stacking cable out of the same material.
Thanks everyone! That’s straight forward and helpful, appreciated
Will order a number of cables based on all that
Xinhs is the best store on Ali
Ok that goes beyond retuning. Interesting…
Yes, definitely.
I’m also interested in their upcoming earphones, hoping there will be a successor of GD3A. Getting a high rating from @Rikudou_Goku with just under 100$ is pretty impressive, tho it was a deal breaker for me because of no vent
If they do what they did with gd3a and a dd, i mihjt jump on it
They seem to appreciate my feedback to them. As they have asked me for my mail so they can contact me easier. Let’s hope they take my advice regarding the vents.
GS Audio x RikudouGoku GD3R incoming
DBZ face plates, xinhs cable and radius deep mount tips
GS Audio was talking about GD3C , so it might be just that
Not gonna lie, I would instantly buy that.
Me too ofc, minus the dbz face plates
It is only an issue if we ever get a company X luizgarcia IEM. The bass shelf alone would crack the Earth’s crust.
Ahah that would be funny. Or special packages…
Resolutions pack would come with 10 tribids + mest mk2 and mine with Teas + 10 xinhs cables cables
So basically a narrow bore nozzle and a wide bore nozzle. Well extra choice is never a bad thing.
Its like the filters that LZ uses probably. They arent actually wider or narrower, just different amount of damping.
That works too. The only possible issue is that if it is tuned too in between to different sound profiles so that neither is as good as it should have been. But most filters and tubes are not so different from each other and Dunu does make some really good products… so the odds are low.
