Looks like a generic type like the ones XINHS cables come in :man_shrugging:
I have this case, and while it has a nice linen-like texture on the outside, the zip is not high quality. I prefer the Tripowin x HBB Mele box (and zip).
it’s definitely a generic type i’m just wondering which generic type it is, i’ve used one before that came with est 112s that i resold on ebay, sorta wish i kept the case now, i’d be pretty surprised if dunu were making their own cases, i’ve got a couple xinhs cases too they’re the 2nd best besides the dunu cases imo
honestly dont know, XINHS has the closest looking case though.
(GD3C)
2021-11-25: Shuoer EJ07m: LETSHUOER (Shuoer) EJ07M - Reviews | Headphone Reviews and Discussion - Head-Fi.org
Rank: S+
A great complement to the Dunu EST112.
Hi
I just received the Fearless Provence and it exhibits many GS Audio tech choices. Similar construction to GD3A, with more bass quantity and slams significantly more than GD3A due to mid-bass focus on Provence. Nice fast impactful kickdrums.
So, they can do it the way I like with that side-tubed DD and much likely they will be able to do great on GD3C with your target FR. Just be patient :wink:
(Fast notes : no vent - great build - no 5-6 kHz peak - bit less treble extension than GD3A - same mids quality but colored by mid-bass)
Cheers
I’m rather gobsmacked by the quality of Faaeal Iris 1.0 earphones. Fancied some light headphones with similar-ish signature to PX-100 II, and various Koss’s. Heard that these packed a good punch, and hit similar notes.
Very happy I listened to the recommendations. They’re great.
Black Friday sale:
KZ BA10
CCA CRA
2021-11-28: 100 IEMS Ranked!
Batch ranking:
Iems:
Intime Sora Light 2019: A (hard to recommend due to QC and hard to buy it for people outside Japan)
Sennheiser CX400BT: B
Sony WF-1000XM3: B+
Earbuds:
Koss KPH14i: D-
Philips SHS3300: D
Headphones:
Audio Technica ATH-R70x: A+
At this point, I have 100 iems, 36 earbuds and 15 headphones ranked. :grinning_face_with_smiling_eyes:
With 4 more iems (KZ BA10, CCA CRA, Tanchjim ECHO and GS Audio GT12x) and 4 more earbuds (K´s K300, Qian39, ShoonTH ESEP-01BL and Astrotec Lyra Nature Limited Edition on the way right now.
ShoonTH ESEP-01BL mini review:
Rank: A
Non-sound: Microphonic cable, plastic/metal shell, inferior to MX500 shells in comfort/fit for me.
Sub-bass: poor extension and lack of rumble, doesn’t have much quantity and lacks texture, not particularly fast or tight despite the low quantity.
Mid-bass: A little bit elevated, decent texture is on the tighter/faster side.
Mids: Warm vocals, good tonality with both male and female, forward as well. Pretty clean as well.
Treble: warm vocals but is airy, not peaky but well-tuned.
Technicalities: Average soundstage, but impressive imaging and separation. Detail is average.
Overall: I don’t really think it is worth the price of around 30 usd. Its only a bit better than buds around 10 usd technically, and tonality wise at least for my library is inferior to those buds (Yincrow X6 & Faaeal Iris 2.0 for example). You are better off getting the K´s LBBS instead or sub 10 usd buds.
2021-12-02: LZ A7 mod (KZ DQ6 upgrade)
Just a headsup, if you put tuning foams into the black filters on pop settings, it sounds very close to an upgraded KZ DQ6 + Tuning foams.
All you need is this:
(high density version)
  1. Remove the stock metal filter on the nozzle (the side that is going into your ears) by using something like a needle or a sim card ejector.
(irreversible since it seems you cant remove it without putting a hole in it.)
Take one piece of tuning foams, and put it into the nozzle where there is now a hole. (one piece per side.)
Should look something like this now. Done :+1:
Pop-red + high-density tuning foams > Pop-red
Bonus:
Also, if you dont have tuning foams but do have the filters that comes with the Tanchjim iems, you could substitute the foams for those filters and the results should be similar.
I’ve tried the Tanchjim filters on DQ6 since I now have the O2 and…I was disappointed. I thought that it made it sound thick and narrowed the soundstage.
After some A/B testing with my other IEMs I came to the conclusion that it was great for rock/metal which is what people have been saying all along. That’s about 2% of my library these days.
Am I the only one to notice a strange timbre while listening to classical music with DQ6 giving instruments a sort of metallic sound to them?
I tried my best but I’ll be selling my DQ6 while I wait for the ZEX Pro.
O2 filter reduces the treble a lot AND increases the bass.
So thats not a surprise.
But I suggest that you try the high density tuning foams:
https://www.aliexpress.com/item/1005002711483821.html
(they work like magic for the DQ6 and a lot of other sets as well.)
Based on your graph, it looks like the filter reduces the upper mid range. I believe that the issue i have is with the area from 4k to 10k that’s too high and spiky.
The other issue i have with the bass is the lack of energy around 3k. I think it makes the low end too warm.
The good thing is I’m learning more and more about what i like and what i don’t.
Aa right, 4k+ isn’t affected that much by foams/tanch filters.
I have ordered a lot of other tuning materias so I will see if there is something that can affect the 5k range besides the 2-4k range.
Nothing I’ve tried so far has completely fixed the treble in the DQ6, just made it bearable more of the time.
Have you tried EQ?
It’s not something I like to bother with moving between devices and operating systems, so I haven’t.
Same experience here. I just moved along 🤷
