Oh btw, @Rikudou_Goku , I bought an MX500 earbuds, not from Nicehck audio store tho. It is from Jietu and I think they made these in house?
I am really enjoying them without full foams. Putting on the foams make them become bass canons and sounds really bloaty and compressed. Is there any workaround you would recommend to use foams without making them sound too bassy?
Or do I just simply not use foam . I mean, it is simple as that if I think about it, huh
You can try donut foams (the ones with a hole in the middle) or low density foams. Trig rain has low-density foams but god damn they are not comfortable. @nymz has Venture Electronics low-density foams, so maybe you can try them instead.
The package is similar but the cable is different and the driver inside might also be a completely different one.
It’s listed as DIY MX500 on JieTu Lazada.
Pics below
That cable alone will probably affect the sound even if it has the same driver.
Due to the different cable thickness affecting the airflow on the MX500 shell.
(you thought I turned into a cable memer right? )
I have to say, the VR3000 does feel a bit cheap compared to the Mele. The plastic shell is very light and minimalist. The plus side is that the shells are very light. Fit is a bit strange for me as the insertion is deep and the entire shell has to really push against my concha. Luckily the stock tips are comfortable and seal well. Cable is also plastic and feels a bit cheap.
Sound: Burned them in ~24hrs prior to casual listening. Will do more critical listening tonight, but off-the-bat, this is very pleasant to listen. Nothing offensive, pretty balanced. Very good holographic representation, good microdetails. I’d say sub-bass quantity << Mele, but decent quality, mids similar to Mele, treble > Mele in extension. Tonality is good. Jazz is sounding good, and so are original film scores. For £19, I mean, no brainer. For £49, still think it’s a decent deal, partly because you don’t need to spend extra for cables and tips, and you get a build-in mic. Will post more impressions and comparisons later!
Yeah, I agree to a certain degree, but mostly it’s due to us being too used to the Chi-fi marketing and IEM materials that creates the sense that plastic shells are cheapish. Yet, among plastic items (e.g. QKZ VK4) VR3000 is excellent for the type of plastic and rubber it uses I’d say.
Doesn’t that mean that the fitment is shallow tho?
If you mean that the insertion needs to be deep for a good seal, then I feel the same ha. I said elsewhere that these need longer stem tips, and I recommend Spinfit CP100 and Azla Sedna Regular. CP100 actually has the best resolution, but Final E tips are still good as long as one can create a good seal (I can’t). The shell shape is truly the only downside I can find, I think for some the shape will create discomfort. Solution is again, try longer stem tips.
I think Final Audio freaking nailed it with the “Made for VR, ASMR, Gaming and 360 Music” description. Normally these types of advertisement for IEMs are just talk and flourish. Not these. These are LEGIT.
Blockquote
Sorry, I wasn’t clear: Deep insertion is needed for a good seal, so I have to push the whole shell against my concha. If that means the fit is shallow, then yes! Still learning I get a very good seal with the Final E tips, but I can try CP100 later as well. I don’t find the shells uncomfortable; I was just surprised at how deep the nozzle had to go in lol.
Similar to the DQ6 but with more bass quantity (worse quality), not as peaky treble but less air and overall technicalities are below the DQ6.
KZ ZEX Pro:
Tuning is very atypical of KZ. Going for a more balanced tonality, without recessed mids. Bass is slightly elevated and does have pretty good texture (although not as good as the DQ6). Mids are not recessed/forward, but more neutral. Treble is where it needs more work though, as the upper-treble is lacking air and extension, while it is a bit harsh overall due to the 4,5k area and there is a real peak at around 8k. Overall resolution isnt much different from the other KZ´s, it is around the DQ6 level.
Alright, here is the Version 1 mod for the EDX Pro. Stuff in 2 pieces of LOW-density tuning foams (not high density like on the DQ6). Removes the peaks, while retaining everything else.
