Really curious of this one… what your thoughts will be, Didnt you measure the LitzPS and it wasnt great.
That is the cable out of the 4 cables, that I got the least expectations from lol.
Yes, I did measure both the LitzPS and the Limpid (same cable) and they dont measure that well. Thats why they arent in my default recs.
I have the limpid, I didn’t think it was that good. Plus it’s my most expensive cable…most of mine are 7 to $10.
I dont have any sub 10 usd cables though. Although I do have a KZ “upgrade cable” and a TRN cable, thats probably around that price and the build quality is really bad on them.
Are sub $10 ones usually built bad?
Yes, thats why I dont bother with those cables anymore.
The best cables for value is the faaeal litz copper cable.
I don’t have that one, but I was gonna try it cause I heard it was really good. I saw a measurement chart you have as well showing how they scale.
Well, that XINHS shop on ali has some that are around 10-12usd and they look fine…
But you can never know… its Chi-fi
True, but we see, I think that if the cables around 20 usd are as good as I think they are. It should be better to go for those instead of saving on the cheaper cables.
The cables around 20 usd are the cables I use for my 300 usd iems.
So much unit variation…
Okay that’s something I thought might be true. Those under $20 ones seem too cheap.
yeah, but thats to be expected at such a low price.
high quality materials are already more expensive than the damn cable…
They mass produce them in large batches, thats the only way to keep the price that low and QC will suffer in big quantities like that (and because they dont have much cash left for QC…).
I didn’t know they produce in mass.
I purchased some questionable Yinyoo cables which get good reviews. Quick question: how do you measure cables?
They have to, and thats why prices are low but QC is bad because there is such a large amount.
Get a multimeter.
I use this one
https://www.amazon.com/ANENG-AN8008-Multimeter-Resistance-Capacitance/dp/B076GZK62B
It is on aliexpress as well.
Where did you read the good reviews from? They are banned from head-fi so I doubt you found them there. Was it on aliexpress?
It s so fkin hilarious :smile:
A cable company banned from discussing on a discuss forum.
They make other stuff than cables as well.
Oh wow, that bad huh?
They had good reviews in Amazon and some site called the phonograph? It was these or getting FiiO’s for twice as much, figured they can’t possibly be that bad right? Worse than the stock cable of the T2 and fh3?
I have a multimeter, do I just touch an mmcx connector and the plug at the same time?
