Didn’t see any official thread for this so I figured I would make one.
Specs from Schiit:
$199 no card
$299 with 4490 module
$399 with multibit module
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-400KHz, -3dB
Maximum Power, 16 ohms: 5W RMS per channel
Maximum Power, 32 ohms: 3.5W RMS per channel
Maximum Power, 50 ohms: 2.5W RMS per channel
Maximum Power, 300 ohms: 600mW RMS per channel
Maximum Power, 600 ohms: 300mW RMS per channel
THD: Less than 0.002%, 20Hz-20KHz, at 1V RMS, high gain mode (worst case)
IMD: Less than 0.002%, CCIF at 1V RMS, high gain mode (worst case)
SNR: More than 115db, unweighted, referenced to 1V RMS, in low gain mode
Crosstalk: Less than -87dB, 20Hz-20KHz
Output Impedance: Less than 0.2 ohms in high or low gain mode
Input Impedance: 22K ohms
Gain: High = 6 (15.6dB) or Low = 1 (0dB), via rear switch
Topology: Fully discrete, current feedback with Continuity™ constant-transconductance output stage and stacked power supply rails
Protection: Standard muting relay for delayed turn-on and fast turn-off
Power Supply: Internal 48VA power transformer with 4 separate power supply rails and over 20,000uf of filter capacitance
Power Consumption: 30W
Size: 9 x 6 x 2"
Weight: 5 lbs
The measurement graphs show a stupidly low noise floor, could be a great powerful amp for IEMs
