It should be quite different. Many would say better.
Hope the rnhp and BH crack work well with it.
The BH and the Bifrost are common pairings Iāve seen recommended. ![]()
Iāll say better and I actually donāt do that often.
Also, donāt be alarmed if it doesnāt sound superb right out of the box. It does take some time to have the electronics get up to temperature. Just make sure to leave the setup on and it should sound much better as you are breaking things in.
My jotunhiem got WARM. Howās this to leave on?
Yes, it might take like perhaps 10 minutes to sound itās best
I left my Jot on 24/7 got warm.
I leave my Gungnir Multibit on 24/7 it gets warm (I think Schiit actually recommends it for the Gungnir)
I leave the Bifrost 2 on 24/7 if getās less warm, but still warm to the touch.
R2R DACās are significantly affected by temperature, so youāll want to be listening after it warms up, first 20 minutes are going to be the most critical, but itāll continue to change for probably at least hours.
There are people who claim that the Yggdrassil sounds itās best a week after itās first turned on, though I doubt that sort of warm up time is really having much of an effect.
Yes if you can leave it on, do so, no real harm done
Got it. I typically turn off my smsl and rnhp.
Lately tho, Iāve left them on because Iāve been burning things in when not actually listening.
I turn my Valve amps off to preserve the life of the valves, but all the SS I just leave on, components generally behave best once they reach a stable operating temperature, the time to reach that varies based on how localized the heat generation is, how big the enclosure is etc etc.
My Whammy amp takes a good 24 hours to stabalize in temperature, largely because all the heat generated in the case is localized, and it has to heat all the air in the case and then the case itself.
Awesome, thanks. How have you liked the whammy?
Itās my favorite amp with the Aeolus.
I have a Burson op-amp Iām going to stick in it when I get a chance to see if it has any significant impact.
Iām going to add a strong statement to my impressions of the Bifrost 2.
Itās really good.
I thing itās better if you have a single ended amp than the Gungnir Multibit.
Thatās a highly respected DAC that cost 2x as much.The Gungnirās better balanced but I have a number of amps where I prefer the Bifrost 2.
I can agree with this, the B2 is very impressive for what you can get it for
Do you guys know if BF2 can output to xlr and rca simultaneously?
Pretty sure it can no problem
My Bifrost 2 is ready for pick up⦠May have to run out this evening.
Iāve got a friend that has one. Doing a listening party this weekend. 5 DACs, 7 amps, 11 headphones.
Sounds like a good time lol
