Just wondering if anyone uses the Schiit Jotenheim?
I had one for quite some time.
Jason Stoddard approached me the other day and is sending a Jotenheim for me to play with in conjunction with my recently purchased Bifrost2. He thought I might like to see how it compares with the THX AAA balanced amps…It should arrive today! ![]()
https://www.schiit.com/products/jotunheim
Amplifier:
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-700KHz, -3dB
Balanced Headphone Output:
Maximum Power, 16 ohms: 7500mW RMS per channel
Maximum Power, 32 ohms: 5000mW RMS per channel
Maximum Power, 50 ohms: 3000mW RMS per channel
Maximum Power, 300 ohms: 900mW RMS per channel
Maximum Power, 600 ohms: 500mW RMS per channel
Single-Ended Headphone Output:
Maximum Power, 16 ohms: 2500mW RMS per channel
Maximum Power, 32 ohms: 1500mW RMS per channel
Maximum Power, 50 ohms: 800mW RMS per channel
Maximum Power, 300 ohms: 350mW RMS per channel
Maximum Power, 600 ohms: 175mW RMS per channel
THD: <0.001%, 20Hz-20KHz, at 1V RMS
IMD: <0.0015%, CCIR
SNR: >109db, A-weighted, referenced to 1V RMS
Crosstalk: >-70dB, 20 Hz-20KHz
Output Impedance: Less than 0.1 ohms, balanced or SE, at both gain settings
Input Impedance: 50K ohms
Gain: 2 (6dB) or 8 (18dB), selectable via front switch
Inputs: Balanced XLR and Single-Ended RCA, selectable via front switch
Outputs: Balanced headphone (4-pin XLR), single-ended headphone (1/4” TRS), balanced line preamp, single-ended line preamp
Optional Inputs: Multibit DAC, AK4490 DAC, or Passive MM Phono
Gain Stage: Proprietary Schiit Pivot Point™ fully discrete differential current-feedback topology
Power Supply: One 48VA transformer with 6 stages of discrete or integrated regulation and over 70,000uF total filter capacitance
Optional Dual AK4490 DAC:
USB Input Receiver: C-Media CM6631A
D/A Conversion IC: AK4490 x 2Input Capability: up to 24/192
Analog Output: fully differential, active summing and filtering
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2-100kHz, -3dB
THD: <0.001%, 20Hz-20KHz, full scale
IMD: <0.001%, CCIR
S/N: >108dB, referenced to 2V RMS, unweighted
Optional Multibit DAC:
D/A Conversion IC: Analog Devices AD5547
Digital Filter: Schiit Comboburrito Time- and Frequency-domain Optimized DSP filter
Frequency Response: 20Hz-20KHz, +/-0.25dB, 2-100kHz, -3dB
THD: <0.005%, 20Hz-20KHz, full scale
IMD: <0.006%, CCIR
S/N: >109dB, referenced to 2V RMS, unweighted
Optional Passive Filtered Phono Stage:
Gain: 42dB
THD: <0.01%, A-weighted, at 1V RMS
SNR: >80dB, A-weighted, inputs shorted
Crosstalk: -70dB, 20-20kHz
Sensitivity: 2.3mV for 400mV output
Overload Margin: >20dB
Input Impedance: 47k ohms
Input Capacitance: 100pf
RIAA Accuracy: +/- 0.25dB, 20-20kHz
Topology: Fully passive RIAA network with AD8599 gain stages and PET film capacitors throughout, DC coupled, with DC servo
Power Consumption: 25W typical
Size: 9” x 6” x 2”
Weight: 6 lbs
APx555 Report for Jotunheim
APx555 Report for Jotunheim with 4490 DAC module
APx555 Report for Jotunheim with Multibit DAC module
Alex
