šŸ”· Schiit Magnius
The RHNP is a class AB design but it is biased into Class A for all intensive purposes its a Class A op for most listening…just because a certain chip or transistor is used makes it automatically be a certain class of amp by definition.
Well, in case of an integrated Class AB amplifier chip, it is a little difficult to change much of its behaviour unless you have the manufacturer customize them for you.
If you had a look into the datasheet for the TPA6120A2, you would see it does not offer more customization options than your average 8-pin Dual-Op-Amp.
To be clear: It is possible to bias Class-AB into Class-A, looking at the PCB shots available on the internet, unless there is some circuitry on the back of the PCB, there is no biasing happening.
Totally understand and agree…I sent a note to Neve and have asked them the question directly. Nothing like asking the ā€œsourceā€ vs us guessing out here…
If I get a response I will post.
I also will pop mine open and take a look at the bottom side of the pcb…do you have a schematic of this amp?
https://tangentsoft.net/audio/opamp-bias.html
Tried sending u a message…
I received a nice response from Neve:
"The amplifiers are biased for operation between a 0V and 24V rail (The input is biased to +12V). That may be where the confusion lies? But the RNHP is a class AB design, and does not have a transistor biased output stage like many of our other designs. The headphone amp in the RNDAC has a mostly class A signal path, but the output amplifier is still a class AB design. "
FYI
Alex
