dac is it must?or can i skip the dac ?
not recommended to skip the dac. You can, but not recommended
I did some research and i found this video ,about its hard to notice any difference between amp and no amp.
what i will notice by buying amp or good amp?(i do not have golden ears so no taste in sound )
ps. volume now is high enough from my pc
Sound demo videos usually are not very reliable and tend to face compression. They should not be viewed as a guarantee that this is what the headphone sounds like. If you listen to a sound demo with another headphone you will get mixed results as your own listening equipment also has a sound signature. Demos give you a general idea.
There is also on some cases where you get people who cannot discern the sound differences⦠which is fine, or they use a sound file that is not of high quality so theres less noticeable changes
from you experience ,buying an amp usually i ll notice huge difference compare using motherboard?or just 5%?
Depends on the unit and motherboard⦠for me going from board to say a liquid spark⦠noticeable difference around 30%
i did many test the sound happened in front of me i feel it in my head not in front.
is dt880 work this way?
i used this file
(https://www.dropbox.com/s/2dah95pm41tmj9w/Abyss%20Headphone%20Test%20Lossless.wav?dl=0)
did you get the 880?
if yes, then the answer should be obvious that no⦠the 880 does not have imaging issues.
do you have an amp driving the 880? is it powerful enough, is the dial needing to be above 85% to get āloudā?
If you do not have an amp, or the dial needs to be pushed too far get to a loud status then this can very well be the issue here.
Cannot speak of the validity of that particular test, as someone who has used 880 in competitive gaming⦠as well as knowing many many others who do the same⦠it has zero issues with placements. As far as placing things in front, top, left, etc it also can take time to get adjusted based on the headphone and its respective staging⦠or whatever your listening to
https://www.youtube.com/watch?v=zvNjy6oruhA this is a youtube video but it is a good enough representation of imaging. Just used the 880 connected to my setup during that video⦠no issues, could place all sounds in their respective direction including the details with everything
