Yeah. I really wanted to get a matching one too. But Iâll just console myself by pretending that the colour doesnât match. Donât tell me otherwise. Lol
For the record, I think you have more sense than I do.
I have to agree with you on that one⊠contemplating buying one more for matching coloration is⊠well⊠worthy of a true audiophile
$75 isnât the worst Iâve seen, though the XLR plug looks cheap AF. $240 for a 1.5m wire though, oof.
I suppose Iâm just too poor to be a true audiophile. Lol
Itâs like high end graphics cards. So few people are going to buy them, they have to charge a fortune to make any money.
yknow as well as I do the only reason Nvidia is charging as much as they do for that 2080 ti is because they have no competition, lol. They really jacked up the prices this gen.
Well AMD jacked up their prices this gen too, despite switching to the cheaper GDDR6 RAM.
ah⊠hmm⊠well I kind of hope things settle down a bit on pricing. $1200 was a bit steep for their flagship. Which I swallowed⊠I donât see it happening until AMD can challenge them in their higher tier offerings though.
Kinda like Stax then.
Well, stax has competition in their lower end by koss and in their higher end by kingsound, hifiman, mrspeakers, Sonoma/Warwick, senn, and other smaller brands
I also had the issue with the headband being almost too big on the smallest setting. Someone suggested turing the mechanisms inside out and pushing the strap through the metal headband and then connecting them on the outside. If that makes sence. I did it and solved the problem for me
You got a picture of that?
I had to use them on the smallest to fit me, they were to big for my wife. Now on that setting with about 5mm gap its perfect for me and fit my wife now on the smallest setting
Did try wet forming the leather but didnt work. Liked the look of the Meze Emporeum and the way it contours but couldnât get the leather to for as I wanted
Thx!
Looks fine, so that is a neat way to go in case needed.
Its not ideal, but for now it works. Want to get a custom piece of leather made thats just a bit smaller so that I can change it back lol
