šŸ”¶ Shuoer EJ07M
Wow! Good drawing and it defi helped folks understand how special the EJ07M is! Thank you dude great work
They are indeed special, but I wish if they make the nozzles abit longer.
Also driver flex issue with silicone tips for me … I mean… It seems most of shuoer products have that issue ( after searching) … With foam I didn’t notice thst issue on insertion
Custom, baby. Just wish I could find a 3d scanner around here…
I only get it for a couple seconds after I insert them too quickly, but then it’s cool. I’ll try foams tomorrow when they arrive :slight_smile:
Nope… Not going to make a custom …thanks!
Yeah… Good to know the driver flex isn’t bothering you
For me is the opposite…
They should improve that… They have a bad reputation on that… IMO…
That’s what holds me back from purchasing the EJ07 in the past
@nymz how the bass of EJ07m compares to the Teas? I really like the Teas“s bass but a little more power would be nice. I am really considering this as a Tea upgrade. (Also considering the Clairvoyance)
@nymz
COMPLY T500 vs The LUDOS foam
COMPLY T500 is the thick ones
I have no idea what is the size of the comply tbh..
In general the reason I don’t use foam that much cuz they change the sound for me.
LUDOS For small nozzles like the EJ07M without cutting the foam is perfect for me..
But do they change the sound on your EJ? Sorry i’m really confused…
Do you think Ludos change the sound less than Comply?
These days can’t use IEMs
For me (EJ07M) From memory yeah less than comply but not by much…
(Always foam tips change the sound for me sometimes in a good way and sometimes in a bad way)
U used foame before, right?
Anyway they are cheap… U can compare between the comply and the LUDOS once you get them delivered
No worries…
Corrected my previous post
As what I mentioned before I’m not a foam person…
Sorry can’t decide which tips are good for you… U have to try
You shouldn’t have written that, because now I’m considering buying them, because my Tea is damaged! Although I love metal, I listen to other music and I don’t like small soundstage and bad mids. It seems to me like one of the END GAMES!
Flat sound, normal for a planar.
Man when can I have a wallet like yours?
If you haven’t placed the order - on Shuoer Ali page I can see it’s $549 for U.K. I can apply $40~ discount? Maybe worth checking out unless you will get credit etc. From your usual seller
Work hard bro. Always strive to be the best you possibly can be.
I’m 48 now and in my career I still work hard but I just can’t do what I use to. I use to work all week long till around midnight for 3-4 years straight for the company I worked for and most weekends. Rarely did I ever even take time off. When the work demanded it, I’ve worked 40 hours straight without sleeping. I’ve poured so much effort into my career and trying to be better and better and I’m doing well today because of it. It wasn’t always like it is today though. Life is hard.
I also worked super hard during college. When it comes to careers and earning a living, there’s also luck involved. You can’t force someone to hire you and you can’t stay in a job that doesn’t want you or can’t afford you. I wish I was self employed but I’m not. I tried running my own business and I’m not capable of doing the creative work I do and working the business side with clients and building relationships.
Most people can agree here, I do not have the strongest people skills but I’m always working on bettering myself everyday.
Getting off on a tangent sorry, but the best advise I can give you is to Always strive to be the best you possibly can be, motivate yourself and work hard. Never stop learning.
I’m all ordered. I appreciate the tip though. I feel uncomfortable ordering more expensive items from Ali because I wouldn’t want to fight with a seller and Ali if there was a problem. Cables and little shit I could care less about.
I’m also now seriously wound up with 07M but I do have 07 and 09!
Yes I agree in general with Ali sellers, but the page is Shuoer’s official store - I found them super reliable (had some past brush with damaged 07 during shipping they sorted it out all for me quickly)
Can’t wait to hear your feedback on the 07M!
I feel bad. It’s the first time someone is buying a tribid on my Rec. If I vanish and @Resolution doesn’t like the set, call the cops!
Wait for @Resolution opinion. For me, they are end-game level. Now I just need ultra OCD detailed set like mest, Oxygen and I’m done.
Work your ass off.
