Thank you so much.. Really..
Now actually I am curious to try the cable that @Spa mentioned⦠I am not a cable believer tho
Just to tryā¦
Folks, keep in mind this are only first impressions. Donāt take it as an holy grail.
Also, in another related news, my Xenns UP is @ customs. It might take a couple of weeks to arrive at my house, but can also be a couple days. Letās hope sooner than later, but when they get in I can finally do a deathmatch between 07m x Variations x UP.
@Godria What tips do you use on M? These are a bit sensitive to tips, it seems. Iām using spinfits, so far so good. Any rec?
I am also using Spinfit on them⦠And Final E
The foam I use LUDOS, cuz I have small ears canal
I mean I donāt like foam thoā¦
I didnāt like them with sednaearfit
yeah, I think Iāll keep SF for now. Need to order stuff from amazon JP next week.
Humm I want to say try LUDOS foam, but u may not like them⦠They are cheap tho
They are not like comply foam⦠I mean they are not as thick as comply
Edit: NVM found them.
I find them much durable than comply, and they last longer⦠Plus they are colorful and not boring
I like boring, but sure, Iāll give it a go ![]()
But do you like them or not? lol
Easy to say if you can afford the toll for the Mest. That not a viable solution for most people.
Good for you
Yes, I do like LUDOS foam over comply⦠I am not a foam person, but when it comes to foam I go with LUDOSā¦
Have you tried stock tips? I usually donāt care about stock tips, but Iām trying them now. I like this sealā¦
The same⦠Nope I havenāt try the stock tips they didnāt look good to me
Due to the short sound bore, I believe the reason why some folks will need the Tanya filter. I believe Michael B mentioned the Comply T500 being long sleeved seemed work well for him.
I always prefer foam tips for the better seal provides.
Yep, you got to try it - your ears will be the gold acceptance
although, I would say best via balanced port and slightly higher priced ones. Personally Iām not loaded so wonāt go crazy to those costing $200+⦠but for me I can hear the difference, copper sounds warmer; silver colder, gold gives wider space etc.
I think Iāll give it a try⦠I see it sometimes around $100 on sale
Thank you
Or if any of your friends have good cable or pop into any audio shop, in case does not work for you and wasting money⦠just a reminder so that I wonāt be held accountable
Of course⦠I like cables in general so I spend really a lot of money on cables and tipsā¦
$100 is the maximum for me to spend on a cable nowadays lol
