LOL wrong thread
edited
I dont know about scratches seems really durable mine looks same as new after 1 month
IEM threads and releases today be likeā¦
Upon further reviewā¦I know I said I probably wouldnāt try switching the filters due to fumbly fingers. Guess I lied, cause I just did it. And man, Iām glad I did. Actually prefer the black to the red. Not sure what the difference between the two is supposed to be. If anyone could explain like Iām 5 Iād appreciate it. Seems tighter and yet more able to pick instruments apart.
Black filter has a little more upper midrange energy (a little peak around 2k) and the early treble (a little peak around 5k) with a little dip in between to control sibilance (to my ear).
Also, I find it to have a little less sub-bass emphasis on the black filter, which tightens up the bass response for me.
I tried the black filter as well but it can be a bit harsh on the treble at times for me or maybe I am just listening to volumes where I shouldnāt, bad habit when I was a kid therefore itās more important to protect your ears today.
But yeah the black ones seems to pick up the instruments very well and I might give it an another use just to discover more wicked stuff, but with the red one, the EA500s are already wicked.
I tried using horror ambiance, and yeah I got freaked out on some minutes while I was using the EA500.
Yet to see if my red and black are reversed because I find it has better bass and a smoother sound, and usually 2k peak/early rise is a no go for meā¦
They arenāt night and day different, itās just hearing a little more energy or a little smoother sound. Just a touch
I think I have to give the black filter another chance. To my actual ears, there was a bigger difference than the graph would indicate, thatās for sure.
Iāve swapped over to the black filter - same level of enjoyment
Yeah thatās interesting. Iām going to try the black filters now too!
Maybe itās like tips where different tips can sound very different but graph pretty much the same ![]()
They should look different than that looks like two sets of red filters
Goddamn soddin damnitt I promised myself no more cheap IEMs and here I am awaiting a Simgot EA500. When will I ever learn? Answer, probably never!!!
So is it too eary to say the Encounter is a slightly darker sounding EA500 upon first listen. Huskier male vocalsā¦
I do hear a difference. Bass seems louder because pina gain is lower 1-2 db with foam insert into red nozzle.
Sounds a little smoother overall. Just slightly less energy in the highs too.
Have you tried the red nozzles with Low density foam? How does it compare to high density foam?
Just checking, its the āwhite fine meshā in 3,7 ?
Which the seller claims āwhite fine mesh for balanced vocal soundā.
https://www.aliexpress.com/item/1005004485357287.html?
Ali part no 1005004485357287
I have not tried low density foam, I donāt have any. The Black nozzles seems to have low density foam in them. May be tried swapping them into red nozzle and see if there any effect.
Thank you for answering, will just buy both low and high density foams and see how it affects the sound.
