Stop it! This IEM is too nice for you to be getting me to think about popping off the filter and dropping some foam in to see how much smoother the upper-mids can get
Can probably put another damper on the EA500 nozzle as well.
Would at least make the upper mids a bit closer to my target.
I am not buying another EA500 to mod. I am not buying another EA500 to mod. I AM NOT BUYING ANOTHER EA500 TO MOD!!!
100% reversible and zero risks though, just slap a filter on the nozzle
. (foam probably wont fit since I believe they already got some.)
Always wanted an OG dark magician tuned single DD so Iām so in! ![]()
Iād want a second one to A/B as much as anything. It was really helpful when I was messing around with Rosefinch
Yeah, it does help a lot, if you dont have an iec711. ![]()
Also try Transpore tape My Micropore should be here soon but bad it snowed in Vancouver so maybe not.
Interested in hearing the difference I think Micropore is more restrictive. Will post updates.
Actually I went with transpore like you suggested in your video but couldnāt remember the name off the cuff - thatās what I have arriving ![]()
I give you full credit Goobs for bringing this to attention for me. I was waiting for other reviews so glad I got a set.
They donāt seem to want to send me a EA2000 kinda crazy full circle when I told them SIMGOT was off the radar and they finally sent me the EA500. I might have to buy a set of the EA2000 but at $300 if it stinks back to Zero.
You would think if itās any good they would want to keep the momentum going?
I hope Chris you fair better but my budget is very limited.
Your target sub bass is heavenly MM level
You set high standards my friend LOL!
Fuck yeahā¦
Ohhh nice dice analogy. Very fitting the EA2000 itās pricey. We will see.
so I will be getting to try these in the next month and I already know based on the graph I need more bass, do yaāll recommend transpore or micropore tape to cover the vent? I donāt have either so I will be purchasing some in preparation
Not sure the Micropore vs Transpore difference yet. BUT definitely made a difference not sure if itās the same 6db boost That was graphed by Paul Wasabii but I definitely like the results.
I also like the look of Transpore tape itās clear and less sticky.
I love the damn case itās actually useable!
Here is me buying random VE SIE IEM without any prior information on that piece of gear that probably uses shitty driver and has a tuning of OG KZ V shape IEMs but with just a tad better cable, when I could have gotten this (which looks like almost perfect tuning for me (maybe tad more sub bass would be nice)) or even Galileo or Olina SE. Or any other proper set with some information around.
Life is a series of bad decisions hopefully followed by more educated ones. Us lower lifeforms rarely learn from our wins but if we can learn from our mistakes that evolution right there.
The Zen Monk!
You donāt know that yet!!!
Right?
