This is making me feel dirty. Poor Helios. you deserve more
@Antpage2 I was wondering doe the cable terminate to 2 3.5 mm into the headphones or ist the 2 2.5 mm?
How can i tell? theres 2 rings on it
is the plug the same size as a tradtional aux cable that you would plug into like on a phone or a laptop
yeah, its the same size as the head phone plug into the amp
thanks will definitely buy it if I see it cheap enough and if I dont like it ill just resell it for cheaper with a worse cable cause I kinda wanna put it on my he 4xx
