Thieaudio is such a awesome company. First the Phantom, then Helios and now this. Iām tempted to buy this. Zeos really seemed to love em and i really like this company. I gotta do some research and find out how they sound also curious about the switches. such a innovative company. i dont think any other IEM has that feature. I like the look too with the gears
Let us owners know anything youād like to know. Would love to discuss the L3 to help you make a purchasing decision.
There are plenty of IEMs with dip switches
What are they used for? Switches on a headset usually means it has a dsp. or its wireless
On IEMs, they change the tuning. Some dip switches will increase/lower lower frequencies, some mids and some highs
Are these worth owning if I have oh10 and starfields? How do they compare? Been loving on some sub $200 iems.
Youāve covered a lot with those two solid sets
I donāt think the L3 āside stepā would be worth it IMHOā¦but that depends on what youāre looking for?..one set to rule them all? lol.
Yea not sure if Iām missing anything as far as a side grade but wouldnāt mind selling one to replace though hahaha, could just be curiosity hahaā¦do you know much about the Mangird Tea, is that a big step over the L3
Sorry mate Iāve no heard the Teaās but maybe these guys can?..
https://forum.hifiguides.com/t/mangird-tea-6-ba-1dd/13031/15
I was just listening to all of my IEMs last night. It all boils down to what you enjoy as a listener. It is pretty amazing how they all sound so different from one another.
Iāll attempt to describe the Mangird & L3 for you.
The L3 has a pretty good stage for its price range. I think the more drivers in an IEM, usually the wider the stage is. Iām finding that single driver IEMs have a stereo (left/right) field, but usually a blob for an actual sound stage with not a lot of separation (like a 650/6XX headphone). The L3 is very laid back. This is not an IEM for those that require a lot of treble. The L3ās dynamic driver slams quite hard and the L3 is very focused in the mids and low end.
The Mangird in comparison to the L3 has an even larger stage. The best way I can describe the Mangird is as ānaturalā. Thereās nothing that really feels out of place. The stage is very smooth and there are no parts of the frequency that overshadow others. The Mangird lacks the L3ās lower midrange focus and instead has clear and outstanding sub bass. There is no low end bleeding into the mids. The Mangird is also going to deliver much more present highs/treble that are very smooth. The Mangird doesnāt slam as hard as the L3 but the dynamic in the Mangird does a fantastic job.
Both are very light. I believe the L3 is the lightest IEM I own. It weighs almost nothing. Both IEM stems go pretty far into my ears and both create a vacuum inside my ear canal that is quite uncomfortable with silicone tips, so I have to use foam tips with them. I feel the Mangird has more suction vs the L3 in this regard.
If I had to choose one, Iād hands down go with the Mangird. Everything sounds so balanced, natural and correct in the Mangird. The L3 is more fun/less analytical and is pretty heavy handed when it comes to the mid and low frequencies.
The L3 has the dip switched that can also help tailor the L3 to suit your own needs. Some have reported that they have sold their L3 because of the switches digging into their ears. Luckily, they donāt bother mine at all.
Hope this is helpful!
Thanks for the write up! i just bought the Teas so this reaffirms my decision lol thanks again!
My pleasure! Both are great IEMs. If I had to keep only one of my IEMs, I think it would be the Mangird. I enjoy it that much. I just wish I could use silicone tips with it since theyāre easy to pop in. Iām using Dekoni Mercury medium and Comply Sport medium tips on the L3 and Mangird. Some have reported being able to use silicone tips with the Mangird so you might get lucky with your ears!
Enjoy the Mangird Tea! Canāt wait to hear your reactions.
I really enjoy taking photos of my products and sharing them when discussing, so hereās a pic of my Mangird Teaā¦
I donāt own the OH10, but I do own the Starfield. The Starfield is a really great IEM, and most people could probably just stop there. But if youāre looking for larger stage, more natural/balanced tuning, the Mangird is a good choice vs the Starfield. There is nothing āwrongā with the Starfield. It is excellent!!!
Thanks again, sounds awesome. I do have a varity of tips, dekoni foam, spin fit, and final silicone. I like the spin fit the best for the oh10 and the final for starfields. I dont care for the memory foam though
Iām 100% with you. Spin fits are my preferred but I canāt get away with them on the Mangird or L3 and Iāve tried everything I own. The Mangird actually sounds great with foam for my tastes.
Cool, i will definitely try that. The starfields with the foam werenāt too bad, just a comfort thing for me.
OK⦠Can someone help me understand what exactly is going on and why certain IEMs have this behavior and others do not?
I just received the Xelastec tips yesterday. They have a tacky surface and in return create an incredible seal easily. Iāve been experimenting this morning with them on all my IEMs.
Iāve experienced suction on my inner ear with the Mangird Tea and Legacy 3 previously. The Xelastec tips work well with the L3 but the bass is completely gone with the Xelastec tips on the Mangird Tea. Iām not experiencing the suction issue with these tips though. I can not use anything on the Mangird Tea other than foam because of these issues.
Does anyone have any insight into this? Would love to hear from your experiences.
Bass response will vary if a DD canāt move fully, this maybe down to inner ear pressure due to the tight fitā¦if the IEM doesnāt have a big enough porting hole to compensate then this can cause a loss of bass and may cause ear pain.
I got the FiiO FiiO UTWS1 2pin. I can not wait till my L3 will be made. I ordered the custom IEM on Friday. I believe it will be more or less like the Moondrop Starfield. I already own a balanced cable to use with my FiiO Q5s. I am hyped to get my first custom one and first IEM that will not kill my ears because of the Foam or and rubber tips which just make my ears irritated af.
You will get some photos and thoughs in the next 1-3 weeks. Btw thinking about the lack of bass; The L3 have the vent on the inside right? This is good for isolation I guess but also an issue for some ears.
