This is the official thread for the Thieaudio Phantom
- Type: Over Ear
- Amp recommended: Yes
- Open Back
Would it be worth it to merge the original phantom thread with this one? It had so much information about it along with mods, etc.
Ofc, lemme do that real quick
Edit: see below post
Actually I will just link it and leave them alone to avoid anything bad happening, as I don’t want to mess anything up
Do they sell the fuzzy ear pads for other headphones? They look super comfy.
They do not. They dont even come with the phones anymore. Just 2 sets of velour pads. One perforated in the inside and the other 100% velour.
You are ridiculously kind, but I am not. I’m in California.
No worries buddy worth a try though ![]()
Do you think they would wrap around the Fidelio X2 cups? Zeos had ZMF Ori pads around his X1s, which I think are ~100mm diameter. The cups on the Fidelio are ~90mm.
Oof, those are big boys. The lip wouldn’t even touch the cups, sadly. How much would you want for them? I might still give them ago, I don’t mind taping them on.
They’re a tad late to the party
My brief thoughts on Phantom
Next time I’ll compare it with Verum 1 side by side. Which side you are on?
Hi guys ! what combo do you think will benefit the phantoms the most ?
topping L30 + E30
or
Schiit Magnius + Modius
really enjoying the phantoms (have them over a year now)
thanks a lot !
I’ve tried neither, though both appear to be good choices, however thanks to a good deal from Linsoul my Phantom (which I purchased from them) is now powered by a balanced E1DA PowerDAC V2 and with a parametric EQ and other setting applied with the HPToy app, that’s the best it has ever sounded.
I’ll be curious on that comparison. I like the Verum1 a whole lot. The sound of it at least… not so sure about the weird headband!
