🔶 Tin P1 - Planar IEM
This is the official thread for the Tin P1 - Planar IEM. This thread is for discussion and reviews.
  • Amp needed
  • Single 10mm Planar
:red_circle: Purchase Link
Reviews…
Z Review
Your review seems to line up roughly with another review I read this morning here.
https://www.antdroid.net/2019/06/tin-hifi-p1-planar-iem-extended.html
As usual with these planar in-ears getting a proper fit seems to be the biggest challenge. Do dekoni or comply tips fit on these?
Buy on Linsoul’s website, starting ship date is June 28th. Early bird coupon code is: LINSOULP1, which drops the price to $149 (MSRP $169).
https://www.linsoul.com/product-page/tinhifi-p1-iem
Hope they dont sell out, my payday is on the 25th :S
They sold out🥺 but massdrop will most likely still carry them until the 25
Dekoni 4.9mm Mercury fit but I am having a hard time finding them on Amazon in any size but small.
What to buy the DM6 or the P1?
I really like electronic music and rock music.
And I need strong bass.
Will the Earstudio es100 drive these?
These vs Fiio FH5s? I have the Fiios but I’d be willing to sell them to get these (I can’t really afford to have two pairs of IEMs).
They are 20ohm and 95db. Should be fine I believe the Earstudio has pretty high output plus balanced.
I would get a balanced cable for these on the Earstudio as they output over 2 volts balanced.
help a brotha out?
I have the ifi Nano BL which has 3.5mm balanced inputs. I can’t find a decent balanced cable that has a balanced 3.5mm plug on it for the P1? Can some kind lovely person help me locate an adapter?
I just bought used Andromedas for $550 but thinking on selling it just after 2 weeks of using even before seeing Tin P1 review. My problem with Andros are
  1. Comfort - it’s too big inside my helmet
  2. Source transparency which is a good thing but since I use it with my shitty android phone means I’ll always feel I’m missing something.
I also can’t be bothered setting up my portable amp/dac everytime I hop on and off my bike as daily commute (30 mins travel). Do you think I will benefit if I switch to TIN P1s instead? Or should I just, you know, stop being a lazy fuck
I was looking for a 3.5mm balanced cable to, I wasnt able to find any.
There is this which works pretty well, but is more than I wanted to spend: https://www.amazon.com/MEE-audio-Universal-Balanced-Adapter/dp/B076PWSSSJ/ref=sr_1_9?keywords=mmcx+balanced+cable&qid=1561087748&s=gateway&sr=8-9
I ended up getting a 2.5mm cable and a 2.5 to 3.5mm converter (since thats for my phone and my phone isnt balanced, it works fine): https://www.amazon.com/Connector-Earphone-Better-Earphones-Brown-MMCX/dp/B07GS15JQN/ref=sr_1_5?keywords=mmcx+balanced+cable&qid=1561087748&s=gateway&sr=8-5
https://www.amazon.com/BL35-3-5mm-2-5mm-Female-Audio/dp/B07FC1RDDG/ref=sr_1_2?keywords=fiio+2.5+to+3.5&qid=1561087850&s=gateway&sr=8-2
read your message wrong. here is what your looking for. Trust AliExpress at your own risk, but it has good reviews on amazon, just currently unavailable.
EDIT: founds this too: https://www.amazon.com/Geekria-Balanced-Adapter-Convert-Connector/dp/B07BK4BRLV/ref=pd_lpo_sbs_23_t_1?_encoding=UTF8&psc=1&refRID=1RDKQKEK3W3FT3WXKTC2
Will the FiiO K3 be powerful enough to Power the TIN P1?
Hey Zeos, can this match up to Fiio FH7 cus the FH7 sound awesome to me except for the hefty pricetag
Noobie here, will these work for serious gaming? And do you need an amp to power these, or can I just plug it into my phone/pc?
Thanks for the great review, had to pull the trigger on these but now I’m concerned my LG V series phone will not have enough juice to drive these?
Imaging is great, nice highs and he said the sound very good on movies. I can’t see why it wouldn’t be good gaming IEM.
