S12 sounds awesome. First planar too, pretty impressed.
Yes cp145 balancedā¦Final E masks some mids or may be due to higher bass. Have Azla elastic and symbio hybrid but not yet tried also stock tips never opened lol.
And Olina shows full potential (bass) relatively at higher volumes. On Tempotec E44 i am 75% vol step. Amazing separation and dynamics no harsh vocal or treble.
Ordered xduoo link2 balanced dongle since i love their tuning.
Everything updated. Please check if you entry is right.
Sorry for the low updates but⦠bad weeks for accounts across the world ![]()
SednaEarfitLight nice big bore and cp100 xl for me but the sedna sound slight better more bass, no mod
Hey nymz, about the game of cards, some verses have one or two sentences, like 252 card for example have 1 and others have like 20 sentences (like the one i am in
), I donāt know, the matter isnāt very clear⦠Iāve already ordered the tripowin noire, itās not that itās either super important but, I donāt know, itās weird.
Im just the logistics guy. Iāve talked about it with @hawaiibadboy but he is probably busy.
I can try to divide them better, if he wants me to.
Glad that is working for you on the E44 also. Olina does like her volume, more so with dual dampers. Same on the tips, if you are going dual damper, I would use big open bore tips to bring out those big mids. If you notice a bigger bass difference with changing tips, you may be enjoying the vent mod with your ear covering the vent. That is where it came from, if you push Olina in deeper, some chance your ear will cover the vent.
CP100+ and double mesh mod.
i find it helps for longer listening
Iām using the large ones and fit easily lol
Ah ok I think i only used M. Surprised the diameter changes that much between the sized though. Iāll need to try later
Yes Paul thanks for commentingā¦yes i will explore all possible ways to bring Olina to best of my sweet spotā¦but slowly so that i evaluate each step fully.
Yes, and I agree, I think I liked for the same reason it pulls the treble down just a bit so I can wear them all day. It also gives then enough bass that I donāt feel like I need any EQ to help them out. I have been doing the āshort bus modā for two days, and really like the results.
hey mate⦠still waiting for your 2nd part of review⦠when would you get the time to write it? ![]()
Iāve done the mod but it wonāt be for another week, sorry!
not earwax, it is condensation from the sweat in our ears, tripowin knows this problem since mele is out, they did not fix it. if you are sitting in normal temperature condition (20-25 degree C) it is ok but you cannot do any physical activity otherwise sound shut down 90% and you have to let it dry. this is annoying but for the sound quality/price ratio it is ok with me, i use another cheap iem while i exercise as sound quality matters much less when you exercise because there is a lot of external noise and cannot focus on sound anyway.
The TWS one or regular? The TWS got on fine for me. I donāt have regulars to try though
I tried Final E regular M and didnāt fit
