I like stock wide bore due to fit. And honestly, silicone tips will last forever unless you damage them somehow, I donāt see this as a problem. Closest tips are probably Spiral Dots if you somehow manage to āloseā a pair.
Reply button never works, does it?
as gattuso once said, sometimes good sometimes sh** ![]()
at least filters can be bought thatās something ![]()
did you ask how to buy filters?
Wait, thatās Mele filters, not Olinaās. Can you ask if they are the same? ![]()
I think moondrop Spring tips Can ressemble the olina stock tips, too. But beware the size of those: the L spring tips is the same as M spinfit
Iām pretty sure they are not the same. I have both of the filters and the mesh looks slightly different and they are slightly smaller in circumference compared to the olina filters.
I know they arent, I just wanna see the answer ![]()
Ah sorry⦠of course you would know that. I didnāt see it was you that asked that haha. But good idea! See if they know there own products
They really should sell olina filters on the side, just likr mele.
So I just checked on my end and this is what I see if I click on the Tripowin logo to see all their products⦠Over 450 product pages of just olinas ![]()
And I think I might have found your review in the sea of other pages⦠Super strange. But atleast Linsoul is nice enough to offer so many variations of olinas for us, we have so many options to choose from /s
oh boy, this has to be a bug haha. hopefully Linsoul is bothered to fix itā¦
Just to be clear, the ā1Tanya MP on Ventā mod is one tanya filter replacing the olina filter on the nozzle and putting that olina filter on the front vent? I might give it a try. Is there actually any risk of damaging the driver you think?
Has anyone tried putting a filter over the mele front vent and graphing it?
the whole wrap around the neck would be a no go for me.
yeah me too . Iām going to buy KZ AZ09 Pro it looks convenientā¦!
sadly itās limited to Apt-X (vanilla) but its ok⦠it even has a gaming modeā¦!
better option would be FIIO UTWS3 (or 5) which are a lot more expensive ā¦!
I donāt think AZ09 Pro can bring justice to olina potential. Itās good for KZ or CCA iem but maybe not for Olina. Maybe try UTWS3 or UTWS5 if you can stretch the budget.
yeah those are better but I donāt want to use Olina wireless that much. itās mainly for my CCA CRA. anyway Iāll share my feedback once I got it ⦠who knows maybe itās secretly good ![]()
no ldac with those, that was the deal breaker for me
Iām loving my Olina with my UTWS3 however Iām using an mmcx to 2 pin adapter and the Olina keep falling off which is getting annoying
I think AptX is ok and most people (including me) cant tell the difference to LDAC ā¦!
I use LDAC on my FIIO BTR3K just in case ā¦
but it sure sucks battery much faster maybe twice as fast as aptx
