yep all my cables are balance 4.4, using nothing but that
Any suggestions?SE as I currently have no bal. outputs on anything.
Look up XINHS on Ali.
Thanks, very helpful, sounds like similar tastes in music and preferred sound.
Thanks for this. I usually use Amazon, tho. Guessing not silver, since these are
already bright.
Cables on amazon are overpriced and you have very limited options.
Either way, just get one that looks good for u. Or take a look at my cable list.
Will do, thanks again.
tripowin cables are available on amazon Iâd suggest the zonieâs
@CTOXmas Thanks, Iâve seen that too. Do you have one and if soâŠcomments?
very nice cables feel great and are impossible to tangle, much better than most stock cables, I used a few for a while for balanced connections but Iâve started swapping to modular cables
Appreciate using AE can be a bit of a lottery but youâll have no issues dealing with XINHS - heâs great to deal with and his 4-core graphene is my favourite cable (think Iâve got about 6/7 of them).
I can +1 this statement. I made an AE account just to get a Xhins custom cable and do not regret it one bit
my olinas came with the 4.4mm cable which has interconnects for all sizes.
was that the Tripowin Noire cable?
Just ckd. Cool theyâre offering thatâŠlike Hart.
yep thats the one i got, i would get from amazon, quicker
used wd-40 on 4 filters and kept switching them for 2 days now. It condenses to a mute in about 50mins to 2 hrs. But they open up later after not using them for a while. While this is some kinda assurance that the filters will last a long while, it completely demolishes the convenience :â)
I checked the box of contents for the Tanya and filters are not mentioned (while it is mentioned for the Olinas). Pretty much a gamble if i will even get the filters with it. AliExpress is banned in India. The only filters i can find in a few reputable stores are the Moondrop blessingâs filters which apparently has a coating to prevent condensation too. Would those fit the Olinaâs?
well⊠AFAIK wd-40 is more of a degreasing product. you need a anti moisture spray which is used on cloths or shoes. trust me theyâll fix the issue.
no idea about B2 ⊠but Tanya filters are said to have the anti moisture coating on them.
Yeah exactly.
I donât think itâll work on metal because even after using the spray, I see water droplets on the nozzle but filter wonât get wet so itâs fine.
but Iâm also not sure if metal mesh gets clogged by condensationâŠ! but AFAIK metal mesh doesnât tame the sound like fabrics so Olina may become harsh with those.
please donât get me wrong. I absolutely love Olina and solved the issue for my case. my post was just a constructive criticism for @hawaiibadboy or Tripowin. IMO they shouldnât think of condensation as a little problem that may occur to a small amount of people. trust me its a very widespread issue for Olina and many people may even donât notice it. I was just sensitive to channel imbalance and noticed it fast.
fortunately it can be solved easily and I hope next collab wonât have these kind of issues.
