šŸ”¶ Unique Melody 3D Terminator
Sure, the treble is hot, but it’s some of the best, most natural sounding treble quality I’ve heard in an IEM. I wish more IEMs incorporated a DD for treble.
I think it will depend on your library and your tolerance for treble, only you can answer.
I have these ordered to try but I won’t use them if they effect the treble quality. I thought I’d try them out though…
https://www.aliexpress.com/item/1005002116577785.html?spm=a2g0s.9042311.0.0.9e6b4c4daq58JP
I tried the tape mod and do not recommend it. I feel it compromised the tonality too much.
Nice IEM and cable! Well done. :slight_smile:
Filter mod + foam tips + thick pure copper cable not enough to tame the peaks?
I personally hate peaky DD treble, could not live with them in the FD5 even with the tweaks above.
Peaky DD is searingly sharp imo, they just cut like a scissor.
Thanks for the suggestion. :slight_smile:
Witness my thicc CEMA pure copper cable in 2.5 balanced config. I love it so much. It is the cable that turned me into a believer.
You do realize the Graphene cable many of us have been discussing in this thread is a thick copper cable? 8 core is extremely thick (too thick and heavy for some) and measures better than any cable I’ve measured.
ā€œ8-cores grapheneUpgrade Cable LITZ structure Single crystal copper plated silver + graphene earphone upgrade cableā€
https://www.aliexpress.com/item/1005002380254843.html?pdp_ext_f={"sku_id":"12000020435054850","ship_from":"CN"}&gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=ddf6aca9-0cf6-4b67-ba4c-032379311094&spm=a2g0o.store_pc_home.smartJustForYou_6000198554715.17
Have a pic of your CEMA cable measurement?
Is that cable 171 on Hakuzen“s list?
If so, it measures around 0.13-0.14 ohm on his super accurate measurement setup.
https://www.head-fi.org/threads/resistance-of-cables-pics-comments-and-links.907998/
JFYI: There’s another listing for the same cable (same seller):
https://www.aliexpress.com/item/1005002308016313.html
Ref.:
As always, thanks Riku! :slight_smile:
NP, CEMA/EA cables are VERY high quality. Its just that they are also VERY expensive and especially nowadays with XINHS around. Although 2+ years ago and they were pretty much the default rec.
That graphene cable is not a pure copper cable though. I have found pure copper tilts energy more towards bass end of spectrum and appropriately veils treble peaks.
I have the 8 core version. Super supple, great cable all around.
That’s probably a listing for the sale price. I’ve gotten a bunch of them when they go on sale for that price. Grab them while you can! :slight_smile:
Some of us do not believe in cables modifying the sound.
I know… :wink:
But that one’s been there for a while (since the previous sale actually)… :rofl:
Maybe he just didn’t bother to remove them?
I believe there’s also two of the 4-core listings.
(Anyway, I’ll stop derailing the thread now)… :nerd_face:
ok, that is not cable 171.
I speak directly to XINHS and get rates directly from the company because I usually buy larger quantities of cables and custom made cables from time to time. They usually give you good deals on the price as well. So much so I ask to tip him to thank him for his work and time. Incredibly nice guy to deal with and does very fast/incredible work. I’m always very impressed.
Hearing is believing :wink:
I would be surprised if you did not find a difference in say a pure silver cable vs a pure copper cable on your MEST.
It should be sensitive and resolving enough to pick up on it.
Are you using this cable on Timeless? It doesn’t tame treble too much? Does it do any staging improvement?
Or just EQ it instead 🤷 cheaper
I am quite treble sensitive, yet I still love the treble on the 3DT. It just so happens to be my favorite part of this IEM. I hope that should tell anyone that the treble on the 3DT is different/special.
It is a bit hot as I mentioned earlier and wouldn’t mind it tamed slightly, but I wouldn’t at the cost of its quality.
@Rikudou_Goku suggested trying the filters I linked so maybe they’ll do the trick. If not, it’s not a big deal because I already very much enjoy the 3DT in stock form. I feel it is one of the best IEMs I own especially for the metal genre.
27 posts were merged into an existing topic: No Serious Business - IEM Edition
