I mean, if you want the maximum it can spike to such as the ridiculous mobius then your talking up to around 300 ms. I mention around 20 as thats using something like aptx LL for bluetooth. Note thats just the headphone latency as well… doesnt include net potential issues with lag, monitor lag, etc
Sundara hits pretty high despite its price as is so it makes sense a gaming headset like that wont hold up… gsp are a bit meh in my opinion and those gsp are a bit on the bassier side from my experience with them… penrose definitely had the better sound.
well all headphones have imaging to begin with and this depends on the game. Sundaras strengths arent so much imaging as much as verticality, sound stage, clarity, and overall quality of sound. If were talking just like call of duty or something like overwatch it really doesnt take much whatsoever from the headphone to be considered worth while. Its areas like this that make the penrose feasible… however, when you start bringing in games like Tarkov, Siege, some cases of Valorant, Battlefield, Apex, etc there are certain glaring issues such as apex and its requirement for good verticality placements…
Sundara is good at both very close and quite far due to natural airier type sound signature trait so this is not surprising. In terms of nari that one is decent, but like mentioned it also drastically depends on the game itself. Game engines create limitations. However, the more you play the more you tend to realize where some of these headsets fall short… for example some of the hyper x fall short pretty heavily when it comes to placing sounds diagonally and are pretty dreadful at vertical placements as they will get jumbled between in front and above or behind you.
Well this is why the particular signature is important… clarity is how clear things are coming through, separation is for heated gun battles… some headphones with lacking separation will sound like a garbled mess in larger fps with a lot of players this is noticeable in games like arma, planetside, etc where theres a ton of players all at once… warzone is another case of this, detail retrieval especially in the higher frequencies is what you need to pin down the fps sounds, definition is just extra really… nice to have… not particularly needed imo. Regardless, as long as the signature is in order to help you process and put the particular sounds you need forward then your fine… for example something like the hyperx flight over there is a wireless headset but its more of a W signature with massive amounts of bass… infact the bass is so forward it clouds a lot of placements… this is why Sundara is good because mids and highs, especially the highs, are quite forward and thats where most of your competitive fps sound frequencies are located.
well, chatmix I guess I can see? but things like 7.1 you can just use dolby atmos, hesuvi, or other programs that are either free or dirt cheap to emulate that… other methods you can get 7.1 on are like the Soundblaster g6 amp/dac unit which has a lot of gamer mix stuff while being able to push 600 ohm beyers… so there is other options of course. I think my biggest issue is that wireless is more of a niche area and I wish it was better honestly as I hate wires myself lol. Granted I do own the Hifiman Deva and I could probably connect this to a low latency aptx LL bluetooth unit for gaming but I just stick to what I know with the beyers which work superbly over, in most cases, any other headphone regardless of the fps title.
I mean, you already own a Sundara… if you want the wireless headset for alternative uses or just chilling I don’t see why not? A lot of us myself included own several headphones / headsets. I am not the biggest fan of Sennheisers but atleast I had found the 670 quite comfortable… though if I had to pick my top 3 currently for actual wireless headsets… that would be let me think… Penrose at the top, the Newer cooler master mh670 was shockingly pretty good as well, then itd have to be 670…
I suppose in this sense it depends on how, “hardcore” you want to be in a competitive sense you know? There are those players who absolutely want the very best experience and best equipment to get them to the top of the board each time… meanwhile others play more casually competitive and are okay with taking the lesser units as long as its comfortable and they can enjoy themselves. I think the headsets have their place… but I would never recommend someone one of them in most cases when there are so many headphones out there can be just as comfortable and useful… the only alternative to that is as you mentioned the extra options like taking calls and the like is rather convenient.
