They would be closer to something like a monoprice larger planar (but more refined) or an audeze lcd. Pretty nice headphone for the price
My eyes are getting bigger than my wallet ah!
Just finished the Verum One(old version) short review. I compared the OG pads and the perforated pads in the video, so maybe it can be useful for someone that is interested.
Bass and soundstage are what I care the most about a headphone, so thatās hard for me to choose which ones are betterā¦
10charlimitlololol
WELL HELL, you couldnāt post this 2 weeks ago before I bought some HE560s? Sheesh! Welps, fun money portion of the tax return will be spent on this or the Mofasest Trio. I can only imagine what else is going to magically pop up to alter future buying decisions.
Just going to say properly powered I prefer the he560v1 over the og verums lol
Also that looks mighty interesting, I wonder how it sounds
Hi guys,
I did miss this update, I didnāt like much the old Verum, but this revision is very good looking, Iām thinking of buy one pair.
Just a quick question: is it complicated to remove the grids? I think that a black or a very dark grey color would be nice, they could be painted in 5 minutes.
So they may appear easy to drive, and they can be somewhat run off of a phone, but a powerful amp is something to look into, as the low impedance puts lots of stress on most headphone amps because they are not designed to handle such a low load. What amp do you have now?
You actually might be just fine, should have enough to power the verums. Down the line, I think getting something like the Asgard 3 or magni heresy would be a worthwhile buy, but the receiver would most likely get the job done
I mean the magni heresy should get the job done, is that around 150� If you can I think the Asgard 3 would be pretty great too, so that would be like 250⬠without the dac chip?
verum one or argons?
Hmmmm, I personally prefer the verum 1s, but if you wanted something somewhat closed the argonās arenāt a bad choice
which one has better bass?
The argons have more bass quantity, but I think the verum has better bass quality (and you can just eq the verum for more bass if needed if you have a good amp)
that makes the choice even tougher⦠![]()
I found that even with EQ the Verum1 bass always lacked OOMPH. It was there and it was clean but I never could get the punch I wanted out of them.
Even using a decent amp? The bass could hit hard with the right music for me.
@Jared_S if you want to prioritize bass over everything else I would say the argons might be what you want. If you wanted a higher tier of bass imo perhaps check to see if you can get an x00 purpleheart (but I would argue the x00 is the higher tier of headphone overall imo)
I keep seeing these headphones hanging on the walls of prominent audio reviewers. Are these dark headphones?
Not really imo
