Figured Iād post this here too to share my experienceā¦
We have a very special video today! The Yamaha Home Audio YH-5000SE Orthodynamic Open Back Flagship Headphones; other flagship headphones dethroned?
Bullet points:
-Spacious, immersive sound stage with magnificent imaging and resolution
-Discuss the new orthodynamic drivers
-Fairly Balanced sound slightly warmer then neutral reference however the treble is also very well extended.
-highly comfortable only 320grams
-make comparisons to Meze Elite and Audeze LCD-5
-Discuss several amp and DAC pairings
-One of the best close to neutral reference flagship headphones for my preferences I have ever heard.
-Much more in the video
Hey friends, I finally got my own pair of Yamaha YH-5000Se and wanted to share my findings on the initial un-box and listening. I will eventually make a follow-up video on the TSAV channel. So, after 24 hours of burn, it is pretty audible how much the sound has already changed in the Yamaha YH-5000 SE. I have been taking some notes. The bass was very loose on the first couple of hours of listening, and the treble sounded a bit rolled off. I listened for a few hours yesterday, then let them burn in for another 12-16 hours overnight or about 24 hours or so of constant burn-in, and this morning, now listening again, the bass is much tighter, and the treble is much further extended. I suspect that the reports from NYC Can Jam and The Audio Store, which had them on display for listening, were due to a lack of burn-in and under-delivering current from an amp that is only capable of about a watt of power output (based on can jam user reports via Head-Fi). Stay tuned for further reports on our TSAV YouTube channel. P.S. I love these headphones, and I havenāt been this excited to listen to headphones in a very long time. ![]()
I am unsure how many of you are Roon users, but I am working on parametric EQ settings for the YH-5000se headphones for Roon ARC and Roon Server. I will share them when they are complete. I am not a big fan of EQ; however, Roonās implementation is pretty damn good.
Alternatively, a synergistic tube amp with the YH5Kse does precisely what I like but better with the headphones, which is to smooth the upper mids/treble some and add a bit more bass presence, which makes the overall signature better for my preferences with some tracks may be poorly recorded or that have a focus on vocals and may benefit from a bit smoother/warmer vocal presentation.
With Jazz, Electronica, ambient, techno, orchestral, fusion, and classical, the signature of the YHK5se is pretty spot-on by itself. I hope you all have a great weekend!
Edit:
Another cool thing about these headphones is the ability to swap the pads for a bit different flavor with a bit warmer, more relaxed signature when compared to the more neutral, spacious, and faster-sounding leather pads.
This can be helpful when listening on more neutral sounding solid-state gear or for some recordings that are not always recorded optimally or if you feel like a bit different sonic listening experience.
I am listening to Kitaro and Yosi Horikawa right now off the Hugo 2 pretty epic.
I listened to a pair of these that my buddy swears by as his best headphones, and he has some of the greats, and honestly I found them to be a bit of an enigma. Sometimes I found them to be quite good and other times I found them to be quite average. Either way, they are an interesting pair of headphones and Iāve been working on arranging with my friend a time when I can borrow them for a couple weeks or so to have some time to work with different signal chains, music, etc.
They arenāt perfect, but when they are dialed in, they definitely sound very enjoyable. They are really chain-dependent for me to get the sound the way I want them as well as swapping between the pads lastly they sound better with well-recorded music IMO.
Just to add, these are very unrelenting when it comes to recording quality. Garbage in garbage out. The suede pads make them a little more forgiving but you sacrifice a good chunk of what these hps are great at.
I wasnāt satisfied with my 1st draft, so here is the now complete 2nd (and final) draft fully revamped and improved!
