Yanyin Canon impressions (and comparisons with Tripowin x HBB Olina and LETSHUOER S12)
Context
I had been eyeing an āend-gameā set for some time before taking the leap and purchasing the Canon (note: end-game for my budget). I really enjoyed the Aladdin, which is a 1 DD + 3 BA set, but felt it was time to upgrade. A shout-out to @rattlingblanketwoman and @hawaiibadboy who took the plunge before me and shared their impressions with the community. When I received the Canon, I had already sold my Aladdin, which is why I am only including comparisons to the Olina (with some against the S12 as a bonus).
Preamble & Source
- Yanyin Canon: 1DD (biocellulose) + 4BA (presumed Knowles). SE cable + stock tips.
- Tripowin x HBB Olina: modded with O2 filter + Y4 filter on front vent. SE cable + kbear07 tips.
- LETSHUOER S12: modded with Y4 filter on front vent. SE cable + Final E tips
- Sources: Qudelix & ifi Zen DAC. Using Y-splitter to A/B for comparisons. Spotify (highest resolution offered).
- Bought myself. RRP 349 USD at time of writing
QC, Fit, and Isolation
Ok, no one wants to start reading a review with a QC issue, and Iām being fairly nit-picky about this, but at 349 USD, itās not loose change, so I will critique Yanyin. My Canon shell faceplates have small bubbles (see example in image below, blue arrow). Minor, but also avoidable if they were careful with the resin moulding
The stock cable is really nice, BUT the 2pin connector is very long and acts as big levers that add strain to the connection (red circle). I swapped to a Yinyoo cable with shorter 2pin connectors.
Otherwise, the Canon fit me like a glove. I had the same with the Aladdin, so their shell shape must really jive with me. Passive isolation is very good.
General impressions
The Canon has 3 tuning switches per channel that actually do something (~2-3 dB increase; check out HBB or other peopleās graphs that I shared in this post: š¶ Yanyin Audio Canon - #2 by ttorbic). This means there are 8 different combinations to choose from, which is a great feature but a nightmare for reviewing. For the sake of my time and simplicity, I have settled on 010 (so mids boosted) for the rest of the impressions and comparisons. Why? I found 000 to be fun but a little too much bass for me - female vocals like Adele and Agnes Noble were slightly recessed when the songs had drums/guitar tracks. It wasnāt always an issue, but personally I prefer 010 for general listening, and 110 if I want a more fun bassy sound.
Overall, the Canon sounds amazing. Bass extends very deep, has excellent rumble and impact, and has a great organic sound. Itās not fast like planars, but it adds musicality to the bass. Mids are forward with 010 tuning, no issues there. Treble is also well-extended without any sibilance. I wrote down two observations over and over again:
- Cymbals sound delicious. So clear, so holographic.
- Bass hits hard
The Canon has a decent stage, but the sounds are dense within that volume - good note-weight plus good imaging and layering bring out intimacy (from the vocalist) yet nice reverb/echo and placement of instruments. The Canon sounds like it has Oxygen-like bass (note: I sold my Oxygen prior to getting the Canon, but I do have the Olina and am basing my thoughts on the extensive A/Bing I did with the Olina and the Oxygen), and imaging that is better than the Olina.
I couldnāt find any faults with the timbre apart from the upper registers of the violin, which sometimes sounded a bit plastic-y. I donāt know how obvious this would be to others, so YMMV.
Detailed impressions with songs & comparisons with the Olina and S12
Jazz & instrumental songs
Politely
Canon: good slam, cymbals are delicious, clear, ringing / reverb. Good slam on bass. 35 s with drums intro - very good bass extension
Olina: Cymbals less holographic, more deadpan; separation not as good (Canon very clear left for bass, right for piano until 1 min)
Rosita
Canon vs Olina: Canon better depth in stage but Olina slightly wider. Better echo/reverb; more bass; timbre similar. Canon has more note-weight than the Olina, so the saxophone sounds more full
Swashers
Canon: nicely holographic intro first 50 sec with female voice; deep bass at 1ā10.
Olina: more pillowy bass; imaging of female voice not as good. Stage wide but less height.
TAL
Canon: heavier note-weight. As good timbre as Olina. Width about same, possibly narrower. Similar height. Canon bass slams harder.
Winter 1
Canon: more holographic; violinsā upper register sounds a bit plastic; 1ā33 double bass comes in with more slam.
Olina: good timbre (violins, harpsichord), good air
Vocals songs
My same
Canon: Finger snaps clearer; better layering 1ā when drums kick in, itās behind Adele but still audible. Drums slam more. Guitar sounds nice. No sibilance
Olina: Thoughts based on comparisons to Canon 000 to illustrate recessed mids. Voice a bit more forward than Canon 000; guitar not overpowering Adele. 1ā: drums bit more interfering with Adele than Canon 000. These issues were mitigated with Canon 010.
The curse
Olina: Agnes voice wide, holographic. Good timbre on strings
Canon: Holographic voice; Good layering, voice nicely forward
Nowicaresomemore
Canon: Imaging is better than Olina. Holographic. Good depth
Olina: wide stage; good height; male vocals sounds lighter, less full-bodied
Brief comparison against the S12
It's brief!
Cherry
Canon bass not as fast but more note-weight. Deeper extension. Stage taller and deeper. Male vocals more forward. Detail similar.
The curse
S12: good width and height. Bow tapping clear. Good cello timbre. Violin sounds a bit thin
Canon: deeper, more echo/reverb. Bow tapping clear. Timbre ok here.
Conclusion
Itās difficult to find faults with the Canon because it is better than anything Iāve listened to until now. Sure, I could try to compare with my Sundara, but that will really be apples to oranges! So based on the IEMs I have and my music tastes, the Canon is excellent. The tuning switches make the Canon a great all-rounder - I can essentially apply a hardware-based EQ to fit my mood. More bass? 110. More mids? 010. More treble and air? 001. Yanyin knows how to tune, so you start with a solid foundation, then you can customise to your tastes - what more can you ask for? (I mean, you could upgrade the individual components and throw in more drivers maybeā¦but not sure I need to one-up the Canon for a good long time!)
As always, thanks for reading, and happy listening ![]()
