This is the official thread for the Yanyin Moonlight
- Driver Type: 1DD 4BA 2EST
- Amp needed: No But Better With
Not to be that guy but didnât this thread come a little too late? ![]()
Not too sure but it was asked for ![]()
Definitely a little late considering how fast this hobby moves, but Iâve heard nothing but stellar words regarding the moonlight!
I had it for a brief time and it was a really great quality set. Nothing offensive and definitely a unique (i.e. not harmon) tuning which I really appreciated. The only reason I didnât keep it is because I am not big on having multiple mid/hi end sets as I donât have that much listening time and the IE600 was more inline with my preferences
Ironically, i was listening to the Moonlight when i saw this thread. Iâm enjoying a trip through some test tracks. âWish You Were Hereâ (Pink Floyd)- details in the into are forward in the mix, so the rhythm and solo guitars are nearly the same definition and dynamnic. Details are forward in âLetterâ (Yosi Horikawa). Crisp attacks in mids. Bass - âAtlas - Live at the Fillmoreâ (The Wood Brothers) - decent bass depth and quantity; Iâd prefer a little more texture and definition. Same with âFlight of the Cosmic Hippoâ (Bela Fleck). The bass is immersive, however, and there is a good mid-bass punch in âRoyalsâ (Lorde). Treble is pleasing without percussion or vocal sibilance in âAtlasâ and âCode Coolâ (Patricia Barber). Vocals in 'Bohemian Rhapsody â and âCome Homeâ (New York Voices) are balanced. Vocals are at same dymanics as instruments. The soundstage seems average. Overall, itâs and enjoyable experience. For my ear, I would prefer more dymanic contrast, especially with micro-details that are brought forwardâŠand a little more separation with vocals and instruments. Pleasing without a âwow factorâ.
There are no graphs up on squig.link yet, so here is CrinacleâsâŠ
HBB has a graph of both the moonlight and the mahina
Donât want to write a lot, but only my personal honestly opinion about them.
Fit and comfort. Really bad for small ears fit, so hard to choose tips for them. I want diameter less then 10mm, but I havenât.
Subbass. No it hasnât. If you like dance energy for your tracks donât choose them.
Bass. It here, but only when track has it bass and not enough to me (I listen Hifiman Edition XS, and they have enough bass and sub too).
Mid. Doesnât emphasing emotion and it sad to me (Edition XS do mids much better to me).
Treble. I like planar treble. Didnât hear anything outstanding from electrostatic driver
Details retrieval. Better then all that I had listening!
Maybe I havenât equipment for listening this IEM with them full potential or maybe itâs overhyped set on HeadFi forum. In any case, you need to listen with your ears with your library, but this is my honest opinion about them
Overall this set only for work with music or listening in the background, so as not to distract (You want listening to music without emotions? Really? I donât. *drops the microphone)
P.S. Not sure if 3db will fix all the problems in the HBB version of this IEMs, but if still choosing between Mahina and Moonlight choose the second
Iâm getting a Mahina soon. Itâs eeriely similar to the UP which I had and enjoyed, it just had⊠Say it with me: a bit too much bass.
Mahina dials the bass back quite a bit and that fact together with having Knowles BAs instead of Sonion, I hope will be just enough for that kind of tuning to shine. ![]()
I have heard from some that it works best with clean single ended outputs so Iâll be using that.
Moonlight or Mangird Top?
Maybe also you want check my compilations of information about Xenns Top
: đ¶ XENNS Mangird Top - #2 by Alfeov
Someone noticed that exists a 2023 version of the Moonlight? Same price of the first version (649 $)
Seven Driver Tribrid configuration (1PET-DD+4BA+2EST).
10mm Newly Developed Bio-Diaphragm Dynamic Driver with PET Diaphragm.
Four Imported Knowles Balanced Armature Drivers.
Dual Danish Sonion Electrostatic Drivers.
Four-way frequency crossover with four independent acoustic tube structures.
Hand-Molded Craftsmanship, Intricately Detailed Like Moonlight.
High-Purity Graphene Silver-Plated Cable.
Medical-Grade Resin Shells
graph looks more or less the same plus driver config. Is the only difference a ânewâ DD?
That is the confusing thing, OG description.
new
I donât know. On linsoul I read âThis model features an improved 10mm dynamic driver with a newly-developed PET diaphragmâ.
On their fb page:
"You might not be able to tell from the Linsoul product page, but the Yanyin Moonlight has been completely redesigned for 2023:
Yeah it is very unclear what diaphragm the DD actually is.
But there are more mentions on it being PET only, which aligns with the claim about better long term reliability as bio ones can have issues with moisture.
Interesting that it has added front venting and still manages to hit the same FR
They simply need to change some other damping in it to balance it out.
