So, I’m looking to potentially upgrade my headphones… but am on the fence of if it is worth upgrading at this point.
Right now I’ve got a pair of HD558’s that I’ve been using for a long time gaming and some music… it’s been working well. Now that I have a little more disposable income and have upgraded my PC/monitor… I’m looking into potentially upgrading headphones too.
Problem is… my research seems to suggest the HD 558’s are actually quite good for my purposes and won’t benefit much from a DAC or AMP. I mostly play games, a lot of competitive ones. Mild music use, normally background for working. Electronic (trance, D&B, house… etc), some jazz, some rock/metal… etc. I appreciate sound quality, but am no audiophile (yet). For games, I’ve been into Valorant (same idea as Counterstrike). I feel like sometimes it’s hard to tell where the enemies are… and I wonder if it’s got to do with my headset. (imaging/clarity?)
When I upgrade, I want to really notice the difference. From what I’ve researched, it will take a good bit of money to get that step up for my uses. I’ve seen the AKG 7XX/712 Pro recommended as good headphones for gaming, but are they really a big enough step to make it worth it? I’ve heard the ATH-700x are good, but close to my current headset… and that the HD 6XX/660s aren’t great for gaming due to sound stage issues.
I’ve seen the beyerdynamics 990 600 OHms recommended a lot here but don’t know how it stacks up to the rest.
As for budget… I’m fairly flexible but would like to stay somewhere between 500-1000. That said, I’m still on the fence if upgrading at all is worth it.
Thanks!
. The thread you shared looks like it’s for the 250 ohm version. Those probably can be powered off onboard audio to loud enough levels. I don’t know if the 600 ohm can or not. Onboard audio has improved dramatically over the years and to the untrained ear will sound really good and very close to the quality of one of those dac and amp combos discussed in my earlier post. It’s still not as good as devices dedicated to audio, though. You will likely notice this if you were to listen through a dedicated dac and amp for awhile, then switch back to onboard. You’ll hear extra noise, hiss, and generally less clarity with the onboard. Sometimes it’s one of those things you don’t know you’re missing until it’s not there. Also, onboard audio will require you to use the OS volume control. If the system’s volume control is not maxed out, you lose audio information, degrading quality. Here’s a quick explanation in this thread:
