šŸ”¶ ZMF Aeolus
The dac I just bought sounds very uncolored, it just sounds the closest to real life that I have heard. My spring2 is not that way and more colored by design
If you wanted a relatively clean and affordable r2r, the soekris 1421
Most of my music is electronic and heavily produced. not sure how it would go with that.
Delta Sigma DAC, it what the ESS, 44XX etc DAC’s use.
Basically you oscillate a single bit on and off and then filter the output.
It’s very much like how class D amps work.
Everything I’m reading on other forums seems to point that r2r is generally cleaner and more analytical that delta sigma. The main caveat I see is the absence of being able to use dsd. But again, I’m a dac newbie. But mine sounds good :blush: ha
The dsd implementation is just bad on my spring2 kte, so I just convert dsd to pcm and it sounds great lol
Of all the gear I have, I’ve still never heard dsd :flushed_face: haha. Am I missing out?
Not really, the main benefit of a dsd is the better mastering when they were released on SACD
Ahhhhhh I see. I just use tidal. Works good enough for me. Oooooh the mqa doors and Fleetwood Mac songs on there blew me away. Mqa is pretty comparable to dsd yeah?
Doesnt DSD have higher bitrate and frequency?
If DSD had taken off as a format, DAC’s would be so much simpler.
Not really, I am not the greatest fan of mqa, I personally think a traditional lossless file sounds better. DSD is fundamentally different from PCM audio
DSD64 is 1bit 2822400hz
Yeah pretty true
It’s not comparable.
Basically DSD is 1 bit but at high frequency, it contains no more information.
The advantage is really in the ADC part of the recording process, it makes sense to leave it in that format hence DSD, but it never really got any traction.
I’m so far out of my element. I’ve wanted to buy the thriller dsd album so so long ha. Maybe I’ll jump on it when my Aeolus comes in ha.
Theres so few rock and pop albums on DSD. the only album i saw online was a David Bowie album. Unless you want to buy a SACD and rip it.
Here is a picture of my Blackwood Aeolus.
Which is still in my opinion one of the best, if not the best all around headphone currently…outside of TOTL headphones that is.
https://www.instagram.com/p/B7PRld9p0_Q/?utm_source=ig_web_copy_link
My name finally went onto the build list! :blush:. I was kinda bummed because I thought it would really take forever there were 19 on the list without me even on it yet, however when it updated today, almost all of those moved into the QC status, which basically makes me hopeful that mine are being started since I’m now the second ā€œpending on the list. Wooo woooooooooo!
Ooo…
Mine is in sanding and finishing, and my Eikon is in assembly.
Let me know how the eikon compare to the Aeolus! I want to get either an eikon or auteur next. When I can convince myself to drop that much again haha. Wish I had the courage to drop on 2 pairs at once! Totally jelly! Haha
