šŸ”¶ 7HZ Timeless Planar
1 month is insane…
Last time I ordered from hifigo.com I had 0 issues with vat/customs/etc… I just checked and they have the same priority shipping for Portugal. My package went through Herstal, BE within a day. Customs at Liege-Linehaul, BE is what AliExpress uses and it’s a black hole, but even there it usually doesn’t take that long… may I ask where your package is stuck?
How come?..I ordered my pair from Linsoul/Amazon UK when they were out of stock on 19th Sept and they were delivered 8th of October, no way they should be taking that long :man_shrugging:
IIRC, Nymz chose a bad seller who in turn chose a bad transporter who in turn a the bad luck to get caught by customs.
Scholarship worst case scenario here :brain:
Good things come to those who wait…Timeless :musical_score::ok_hand:
Two filter variations :confused:
Gen.1.
Gen.2.
Basicly, I wanted to review/compare timeless and figure out what was the buzz about it stage /depth/imaging. There was no stock available on normal shops. @Godria hooked me up with a taobao seller and I paid express.
Well, seems he couldnt do express so he refunded that amount and sent it by snail mail… Rest is history.
Urbanfun YBF :slight_smile:
Don’t think it’s Gen1 and Gen2. I think it’s just random. I orderered mine way back when. Mine looks like Gen2 from your photo’s. Sad to say, but really sounds like YBF all over. YIKES!
The photos are switched I think
Same, mine is also the one with the foam under it.
Mine has no foam under it tho. Was looking at the photo it says Gen2. But that can’t be right.
Yep my choice…if you want a soundstage increase with better over all tonality and timbre then :+1:…No it’s still not perfect but helps address some of it’s small $200 foibles :smiley:
(Mine)
Mine..
So which filter came first or do some sets have odd filters?..would explain channel imbalance etc :man_shrugging:
Mine is the same (some black foam, I had to take the grill off to get a good look to see it with the naked eye)
Anyone got the ā€œpaperā€ filter? @hawaiibadboy :man_shrugging:
Agree. Mine had the black foam listed as Gen 2.
I’ve got a second set on the way so i can check.
Ok, don’t know why I thought you ordered from hifigo
who’s satisfied with their earphones ? The blue or the black filtered guys ? :slight_smile: Which better ?
