Iāve got the Timeless for almost 2 weeks now and I must say that it is not perfect BUT everytime I listen to a song that Iāve already know there is something that surprises me. And of all the audio gear I have and Iāve tried (not much anyways ) these are definitely the best technically and tonality wise.
It is like if you were in a narrow tunnel with a fast sub woofer making a sense of fullness while the rest of the frecuencies do their thing (in a good way), and at the same time you can pick every detail if you look for it. I know it is a weird description
So I wanted to take a peek under my nozzle filter and gauze since I found my timeless made female vocals scream at me and bury the music. turns out thereās some tuning foam under that. So instead I put some little tufts of tissue into the eartip and moved them around to adjust sound to taste. Made the sound less piercingly precise and gave it a slight lushness(?).
Overall recommend trying this totally free mod out(or should I buy some tuning foam for that instead since the tissue moves around by itself)
hereās the listing Iām eyeing to try that out: (20pcs)DIY Earbuds repair parts Earphone Front cavity Tuning cotton Tuning sponge Headphone tuning|Earphone Accessories| - AliExpress
My timeless finally arrived. I am late to the party, but finallyā¦
My impression after 5 minutes of listening: Finally an IEM that doesnāt need EQ to suit my taste. Should have skipped the Blessing 2. A lot of subbass. Good treble energy. Good resolution. Might not be perfect, but pretty much what I was looking for.
The Timeless is simply endgame if you like planar sound and use EQ. The tuning is perfect in my opinion. The only real upgrade for me would be the Monarch Mk2.
How long are the cables that come with the timeless?
Cable length is somewhat of a concern for my desk setup and nowhere have I seen length specified on a product page or anywhere really and it would really help to know whether I should order a third party cable or not in time so I wont be getting them, have the cable be too short and then proceed to wait x number of weeks waiting for a third party cable to sort out the issue. >_<
I wouldnāt say it is perfect, but it is pretty good. There is much to like and sooner or later I will EQ it anyways, but the great thing is: According to my taste EQ is totally optional with the timeless unlike with the Blessing 2. For 1x U12T you can get 10x timeless and everyone of them will sound better than the U12T imho.
I just hope it doesnāt brake. I can now understand why @Dynamic got 3x of them
