Iām claiming that dongles arenāt putting out enough power to adequately drive the Timeless. Perhaps volume wise but not in terms of SQ.
New here but thought Iād introduce myself in this post as the Timeless is what Iām currently waiting on arriving.
I ordered mine on Hifigo on the 6th Sep, shipped on 13th Sep, left China airport on 16th Sep⦠Iām in the UK so hopefully have them by the end of next week.
Iām looking forward to these and hoping theyāll gel well with the L&P W2. Iām pretty much a Shure house tuning guy and found that I actually prefer my Aonic 5ās with the W2 to my SE846ās. Iām hoping the Timeless will fill in for the 846ās but with a bit more treble and sparkle. On a listening test the Aonic 5ās extended further both ends of the spectrum to my ears over the SE846ās with no noticeable decrease in details/technicalities that makes the SE846ās worth keeping for me.
If the Timeless can give me a mix of the Aonic 5 extension and liveliness with a touch of the SE846 lushness Iāll be happy.
Someone in here have used Hidizs S9 Pro on Apple Pro and it worked just fine.
how many mW output power needs the Timeless in your opinion
EQ is a very common and requested feature on DAPs.
There are many EQ apps on Android, one that comes to mind is Wavelet.
The DTR1 is still pretty weak and does not have balanced output, something I see as especially beneficial for planars.
I donāt have an exact figure, but as much power as possible without hiss creeping in is good.
Anything below 1W wouldnāt sit well with me in regards to planars.
1000 mW out Nice . The Timeless is really an easy driveable iem
Itās sensitive for a planar. Planar transducers respond differently to more power than dynamics or BA. Planar is a resistive load, meaning the transducer wants to not move and reset to neutral position. Itās only with high current that it can move accurately.
how do you know all this? You never heard the Timeless , right ?
Also BTR5 as well. @11_Clouds has the S9 Pro, and BTR5. If I am not mistaken he said it is enough for them.
I donāt think you need 1W to power them. They are not P1 level.
I agree, this is way easier to drive than P1.
Yes only issue was the S9pro at high volume so I do suggest a unit that has power, although no issues with the Stargate Dongle
Anyone used these with qudelix 5K? This is my plan.
If the BTR5 can drive it the 5K can as well. (same output power)
Yeah I thought so! Excited about these. Just got my 5K, and now waiting for Timeless, Mele and an assortment of earbuds.
youll be just fine, i run Timeless balanced on low gain with BTR5, your main thing will be tip rolling for the right sound signature you prefer
Mine will arrive next weekā¦I think these set need proper break in beside need powerā¦50 hours minimum for driver and 200 hours for cableā¦better use another cable not stock cable unless wait for 100-200 hours for break inā¦and proper seal to get low impact
ā¦yeah noā¦
folksā¦
for such statements enjoy your set
