Which regular silicon tips do you recommend? Foam tips are a no go for me. The Spinfits have been incredibly comfortable for me with the Timeless but Iâm open
They were just name-less silicone tips that piled up from years of buying iems.
My purchase of Timeless also came with âReecho AET07â. Those werenât bad either. Thick plastic on the flanges and tube. I think it was just left-over stock from Reechoâs warehouses. That being said⊠spinfits do fit better. That little notch near the tip can waggle a few degrees which just might fit different ear canals.
There are premium tips, but Iâve yet to shell out for Azla Xelastics and JVC spiral dots.
How do you know what, where to EQ if you donât have them measured? Youâre blind equing?
âBlind EQingâ is what has been done FOH for decades, if you know what you want to fix, you donât need measurements to tell you.
He means to accuratly correct the imbalance on your your set, since timeless is a planar (aka: unbalance fiesta on treble/upper treble ) and every set is different. Also youâd need to eq different channels.
Sure, you can do sweeps all day and try to match it, but you cant look at other peopleâs graphs since every set is different. Itâs the same as trying to eq your GK10 watching crinâs graphâŠ
As long as it sounds good to the owner, it should be done. Same goes for tips, cables, sources, or wtvr. Music is what matters in the end, and anyone should listen it the way they want.
Yeah, @nymz wrote a nice summary. Listen to those words of wisdom.
Oh and buy Teas.
Sorry, misunderstanding on my part, I missed the imbalance part, I was just thinking of EQing in general.
F*ck my life, you know how stupid this is? Youâre lucky to hear above 17k. Canât believe level of insanity LOL
Dat cable is slick. Wanna share the link for it?
I would, but I canât. Itâs not posted for sale.
Itâs a Xinhs custom. You can find his store on aliexpress and ask him to do you one. Just show him a picture
Love Plastikman. How about Robert Hood?
One of the masters, indeed.
Probably a case of imbalance in your original set, that i assume you didnt do tone sweeps to check for, as you had more pressing issue with it(the misbehaving connector)?
If they fixed the imbalance by cutting the frequencies in the louder channel, then it will sound warmer/less harsh. As the change towards that, is there when i do just the 10KHz cut on one channel, if they did the cut to fix lower treble too(theres some at roughly 2-4Khz) it would be even more noticeable. I will be able to do some measurements in a week or two i think, and get some perfect balance so will know the exact change in signature then between balanced and imbalanced. Will try both with cutting and boosting misbehaving channels.
Or you did check the old one for imbalance too before sending it back for replacement?
I donât do tone sweeps at all generally. It really doesnât matter to me if the whole package sounds good.
Not beyond my ears. And, at times I thought the right side was a hair louder. But I have no measuring gear to test things. Nor do I care if my ears donât hear anything that matters to me.
Had the same impression on some things seeming bit quiter than they should be, but was thinking my brain is playing tricks on me, or maybe how the instrument was recorded. And the tone sweeps gave me the real situation.
Cmon now, do it for science on the new set you got
pretty easy to do.
https://www.szynalski.com/tone-generator/
Just hit play , and move the slider. You shouldnt get swings toward one side throught the whole range, if you do, thats where you have imbalance. Small ones are ok, but if it is too noticeable will have certain notes sounding quiter. Perfect set wont have any perceptable swings.
I just did it. I didnât hear any imbalances. But one of the reasons I donât do this stuff is peopleâs ears hear better on one side than the other in any given range of the FR. There is a built in imbalance that your brain is fundamentally burnt in listening to. How does that effect such testing?
Anywho, if I were to test, I would want equipment to do it. My ears, say this set is fine. No idea if the other set was.
If your ears say its fine , then great, thats what is important.
If you hear any imbalance, say boosted frequency in the right earpiece, you switch earpieces lef to right ear, and right to left. If you can still hear the boosted tone in the same ear, then its your hearing, if it switches sides when you switch earpieces side then its the earpiece itself.
Sure, technically. What if both your ears and the set have imbalance at the frequency? Without having a solid point for at least the set or the ears, I am pretty sure itâs still a bit of wild goose chase.
At the end of the day, if itâs final output is good, then I am happy. These headphones are all far greater than the sum of their parts. And I am ok with that.
If I were going to do this seriously, I would purchase measuring equipment. That said, if I hear something really crazy in a set, I will certainly do this. I do sometimes check for sub-bass with a tone generator. I like to know how deep a set can go. (the dusk is insane on that front). But in music, the timeless sub bass just comes across so much better and it canât reach the depth the dusk can.
