Do you have other amps that are plugged in the mains? Do you get hum on all?
For me huming is present when phone plugged in for charging, but no hum when on btr3k and plugging it for charging. It seems theyre pretty sensitive to how grounding is implemented in the device.
I can tell you right now that it out resolves those two. But they both have their own strengths. And I am focusing on presenting each ones strengths and weaknesses as objectively as possible. It just takes time.
Nope I have a Little Dot MKII and no problem plus we live on a barge so weāre on water and run everything including 240v when needed via an inverterā¦so thatās why I prefer battery driven devices
Edit when I touch the amp chassis the humās gone so on @MazeFrameās rec Iāve orderedā¦
Nice, I always go back to the classics when I have a new set. Richie Hawtin and the originatorsā¦Jeff Mills, Juan Atkins, Underground Resistance, Derrick May, Drexciya etc
European minimal stuff like Basic Channel, Maurizio, Rhythm & Sound
And of course Pan Sonic! I love how mechanical sounding they were, with good gear it sounds almost surreal.
YES. Youāre speaking my language. Go listen to Rhythm & Soundās āSee Mi Yahā album on the Timeless. I have never heard an iem that can replay it like these can. The basslines on that album are very difficult for most sets.
Just got my timeless.
OOTB impressions: these sound as amazing as i thought they would! Vocals are perfect. Very good details I didnāt even know existed (coming from KZās). Bass is better than I thought. Slightly less punchy than a DD but better resolution and speed. These are extremely ear tip dependent though, the tips they provide that look like spinfit (yellow) are by far the best ones for me. Still need to burn in.
I still need a dac/amp. Do you think the qudelix 5k will do these any justice? I have an apple dongle right now
Have my Timeless for 10 days now. Fresh OOTB the bass was too loud but tonality was otherwise good. This lasted a whole hour. Its improved everyday since then and what can I say, itās gonna be my endgame for quite a while⦠at least until another planar IEM appears that is significantly better⦠at around the same price!
BTW Dan of Danās Audio in YouTube rates it overall:
Hey guys, I was set on buying the timeless but after reading ~800 posts here, Iām worried about the imaging performance on these. timeless was going to replace my Aria, can someone please compare the imaging and soundstage on timeless, Aria & B2? is it at least on the same level as Aria?
Iāll also probably loose some slam. Iāll try and see if iFiās xBass brings a positive change. If not, Iāll manage with CA Honeydew & AK Diana for that so no worries.
Any IEM recommendations around 300 USD for good imaging & wide stage? recently sold the B2 as they were a bit too bright & shouty for my tastes. Diana has decent imaging but itās capability is marred by some smearing.
I am in the midst of finishing up my b2 dusk, tea, timeless comparison. The first unit I had, had no depth. The second unit has depth similar to the B2 dusk. The tea is bigger.
Yes, typical slam is missing, but sub bass reverberation is not. Basically, when the note pulls from the sub bass, you feel it, but when it doesnāt you donāt. If slam is a priority, timeless may not be ideal. (I am a Zen owner, and love slam, thatās what I go for in my IEMs and the timeless still wins for me)
If B2 is bright and shouty, I donāt know what to tell you. Both the tea and timeless have times when they can be more invasive. My second timeless also lost its shouty issue. But the dusk always came across as the most balanced and least invasive of the three.
Buy a qudelix + timeless and learn to EQ to preferences. This is the first headphone that has made me want to do that as itās other parameters are so good.
Hmm, SHP9500, T2, Aria, Sundara⦠none of these sounded as bright and shouty as B2. I think it was probably poor fit that caused the issue. No way to test now.
Any IEM recs for good imaging & staging? I can get a used FD5 for 220 USD.
I think Iām definitely going to get timeless, but also need another IEM for imaging.
