@11_Clouds it’s pretty nice and will do exactly what you’re looking for. There’s a really good app for your iPad. You’ll just need a splitter to use multiple amps.
Ok thank you for all that detail, so if that’s the case, could I then just use that out to the dac of my choice?
And a dac that can take coax in
Hell yes, I just wanna be untethered except for headphones
Awesom man thank you
That’s going to be your play then since amazon hasn’t really been working to make it easy for streamers lol. The bluesound is pretty easy to use and supports like everything, and while imo not as good of a value prop as the usbridge, it would be better here for sure if you use Amazon and is more refined in the user interface/simplicity aspect
Well I just really like the quality, No need for MQA, just didn’t know about streamers all that well, I hope this works, I’m seeing an optical out as well
Yes it has optical out, but I would suggest you use coax if you can as the optical on there is subpar imo
Wooooo 10 character
Oh good to know
Man I love this forum lol
Jul 13… still for sale maybe?
Good to know about the combo, I am really curious to the streaming world as I mostly use Spotify. I was very interested, but the shipping for me would be $150 and that killed it for me. It will definitively stay in my radar but for now I will go with the Element.
Hey m0n coax is the way to go if I’m connecting the Node 2i to the Denafrips Pontus and want to bypass the Node 2i’s DAC correct?
That is correct
If I want to run this from windows and mac source, which driver is required? I got a little lost in the documentation for this
If you plan to run from windows you get the xmos driver
thanks, and for mac it doesn’t matter? sorry, wasn’t sure what the driverless option meant here
So for mac I think either one will work, but I would go thesycon just in case. The xmos version is nice if you have windows because it doesn’t need anything installed, for mac it shouldn’t matter for either
Mon, hi! Tell me please, how huge the difference between aune x8 and allo revolution? Im installed linear supply to x8, i think it added 10 percent increase in sound quality. Is it worth for my to buy allo? It will be still an upgrade?
