šŸ”¶ Audioquest NightHawk
First impressions after 2 hours of listening:
I almost had a scare at first. I thought there was a channel imbalance but after a bit the center image went back to where it should be.
Bass: Really powerful. Not as much as argons but these are less boomy.
Mids: These are actually pretty mid forward. similar to the KPH30i
Treble: A little bit sharp but also smooth. Kinda similar to the dt880 600ohm but not as revealing with lower quality recordings.
So far I really like the way they sound and it can only get better from here.
Possible endgame for me unless I land a really good deal on th900mk2.
Nighthawk gang nighthawk gang lol
The 900mk2 is pretty awesome, and once you mod them with some lawton cups it gets even better
This further gives evidence to the theory that these have a sort of W signature in a way.
Glad you like them!
They are W with the treble slightly less prominent, but yeah idk lol
Oh followup on gaming, I think the issue I had was I needed to set the eq differently in the latest COD. I was having problem hearing steps etc. even though the imaging was spot on. By changing the in game eq I solded that and these are popping :wink: I messed with some pads more today and I can safely reccomend people to stay away from shure 1840 pads, did not sound right to me. LOL LCD pads are super comfy but loose the bass rumble etc. I tried with dekoni velours.
Did you set the sound to High Boost in Modern Warfare?
Actually it sounded best to me with the home theater eq preset, lol kinda funny to me since they tuned the headphones to sound like speakers. I think just normal boost was really close so kinda a toss up on that as well.
So I’m still loving these more and more every time I listen to them. So much fun depth to the sound and the imaging is head and shoulders above any other headphones I’ve had. I haven’t owned a ton, but still it’s great! I’ve been using them at work with no problems as long as I keep them at a fairly low volume, so I think they will remain my work headphones for the time being.
My only complaint so far has been the much maligned cable. So I’m considering making the upgrade. I already purchased a Liquid Spark for my desktop amp and I plan on getting the BTR5 for my portable setup in the near future. So my cable needs to serve both purposes. I’m looking at the Periapt type 2 cables which I believe are balanced. (please correct me if I’m wrong) I think I want to get it terminated in a 3.5mm since I already have the 3.5mm adapter that ships with the NH to use with my Liquid Spark. Then I would just need to get a 2.5mm male to 3.5mm female balanced adapter to use with my BTR5 when I get it. I found this one that looks promising. Would this setup work? Is there any problems using a balanced cable with an unbalanced source? I haven’t ever dealt with balanced so I’m trying to sort this all out before I start making purchases. Thanks!
You would want to get a cable terminated in 2.5mm balanced and get a 2.5mm balanced to 3.5mm unbalanced adapter
But isn’t the output on the LS 1/4"? I think I would need to buy a 1/4" male unbalanced to 2.5mm female balanced adapter like this one for my desktop setup and that way I wouldn’t need to use an adapter for my BTR5 setup because the cable would already be terminated in 2.5mm. Either way I’m buying at least one adapter. No real way around it.
My bad yes an adapter like this will be needed
https://www.amazon.com/Female-Silver-Headphone-Earphone-Adapter/dp/B07M7L89C6/ref=sr_1_6?
Got it. Does this one look good? Price seems a little better and there are reviews. I’ve bought pads from this brand but nothing else. https://www.amazon.com/Geekria-Balanced-Gold-Plated-NW-ZX300A-TA-ZH1ES/dp/B075FNHDNV/ref=sr_1_5?tag=hififorums-20&th=1
That should work, I just personally prefer the wire ones
Haha they sort of pull you in more than you realize and you end up loving them. Glad to hear you’re liking them more and more!
I finally tried these via tube amp and i think i like them even more than i already do if that’s possible. I don’t understand how or why so many folks dislike these…i mean i know it’s all personal preference but some people really dis these so bad yet they sound so damned good to me. I just guess i have plebeian ears…:rofl:
I’m using these on a hybrid tube and I love this setup too. /highfiveaudiodoppleganger
People who hate these like the m50x
Hahaha, ouch… :rofl:
Alright so I’ve had these for a week now, probably around ~40 hours put into them. I can say that I like these quite a bit more than any other headphone I own at the moment and these haven’t been unplugged since I’ve got them. The 150 hour wear in phase seems a little bogus, but I do think these have opened up a little bit since day 1 I guess? Sound signature seems to be pretty much the same as day 1 though, but idk maybe it’s just me. Let me know if any of you think it sounds different from day 1 (if you can remember lol).
The imaging on these things is so ridiculously good I actually have taken it off of one side of my head to make sure that it wasn’t imbalanced lol. It’s so ridiculous on some songs, might check back in later when I remember to link a few. Bass is nearly perfect with these for what I listen to; quite punchy, no distortion from what I can tell, not overwhelming or muddy. Soundstage is really great too. Mids are enjoyable and I don’t think the treble is too bright, but I don’t think I’m particularly treble sensitive to begin with.
Yeah, these things just kick ass. Super fucking fun to listen to, it’s really hard to want to pick up my Sennheisers unless I really want to focus in on something specific. These are more detailed than I thought they would be, and for personal enjoyment these just easily take the cake for me. For 200 dollars this was a steal.
Thanks for reading, cheers to a new member of the Nighthawk Gang! bikki_peace
Can’t get one… :frowning:
