Might also consider something like an RNHP in that range, which tends to pair pretty well with Beyers.
Thank you guys for your advices. Maybe i should try ifi idsd black label? I hear that it is better than mojo? Maybe i should stay with mojo for first setup and ifi idsd black instead of Allo revolution + asgard/rupert/feliks? Is the ifi idsd black is good enough for 1990? Mojo is really good, im just want to go for higher level;)
is the 1990 a good second headphone if I bought the hd58x?
Depends on your tolerance to treble but I donāt see why not⦠58x is a very balanced sounding headphone with some warm tones to it⦠1990 is a flexible sound signature but out of the box itās neutral bright and quite analytical though itās other pads turn it into a V signature. I would recommend trying the DT 880 or DT 990 before you go straight to the 1990 if possible. Just definitely make sure you have a strong amp for all this.
I have a magni modi stack, Iām also not sure what Iām sensitive to Iām brand new to this and still waiting for the 58x to ship.
Yeah, even more so a reason I would say try the other beyers first with a return policy or a store of some sorts⦠880 would be neutral bright, 990 is the v signature but with more recession in the mids than the 1990. 1990 is like a mix between the two headphones based on which pads you use. since you have magni you shouldnāt have to worry about power issues⦠try the 250 ohm or 600 ohm variants see what you think. 880 has more mid presence than 1990, less treble, semi open back vs open back, and in 600 ohms more bass. 990 naturally has more bass than both pads of 1990, less mids, sharper peak in 250 ohms, smoother treble than 1990 in 600 ohm
are there any other headphones you think would pair well with the 58x?
Depends, so the 58x is more of a balanced signature⦠what would you say your preferences are? Thereās plenty that will compliment a Sennheiser lol
I have zero experience with high fidelity headphones, I currently own a pair of shp9500s I bought mostly for ps4. I mostly listen to metal and rock but a variety of other things
ah okay, well if you were looking for an upgraded version of the shp9500ās I would more than likely tell you Hifiman Sundara would be a definite upgrade in my opinion⦠DT 880 and 1990 could be seen in that case as well⦠but they are more aggressive. SHP9500 is another neutral bright signature but definitely not as bright as the beyers
hmm, well if your a bass lover I would recommend trying to pin down a copy of the Nighthawk Carbon less you prefer a more intimate sound⦠which maybe a meze 99 will suit you well⦠nighthawks were discontinued so they are a little hard to find but they are a bassy and dark signature and quite unique at that while meze 99 is a very pleasantly intimate warm sounding headphone. You could also go with tygr 300r since your a gamer⦠they are a warm-ish V signature as well despite being āgamerā branded they are still very nice and donāt look all that game-y really⦠these do fantastic in any FPS but also work very well in casual settings
Honestly as much as anything I want to try different sounding things to see what I like
well, you tried bright, and 58x can be considered neutral. That leaves Dark, Warm, V, and Harman. Suggestions above work fine⦠if your looking for a V signature 990 would work in that regard just keep in mind thatās a pretty sharp V lol. As for harman⦠I would ask the others whatās a good one for that outside of just using eq to get to that.
skip the 1990 here for the time being till you know your own preferences⦠best not to go spending so much money till you know for sure.
ok, thanks for the advice
There are new dekoni headband and a new pad for the 1990 called choice hybrid
that frequency response chart ![]()
Haha yes looks strange but if you look clearly it just makes the headphone louder
So Iām debating getting the 1990. I have the t1.2 and Iām running an rme adi with the neve. Im pretty sure Iām just thinking the grass is greener on the other side can someone please convince me to save my money lol.
Itās going to come down to signature and tuning, the 1990 will be more linear and neutral bright, with some reduced technical performance and in comparison to the 1.2. So if you feel like you really need that signature change, it could be worthwhile but otherwise Iām not sure if I would do that
I think its not worth when you are already own a t1. Maybe look into a pad swap
Thanks for the help guys really appreciate it
