no worries, I will probably get to them myself soon enough. Provided it doesnât murder the bass I think the pads will respond quite well. Considering how these pads treat the 1990⊠I canât see these being feasible on 990 at all⊠on 880 and 770 though maybe. T1 they sound quite nice
So someone from Dekoni got back with me today. Said that USPS lost my package
So anyway they went ahead and gave me another order number and is now on itâs way.
So I just bought some used 1990 and I enjoy them a bit. They came with some Elite velours and the 8k passive filter. I believe they sound a bit better then the 990s and TYGR, more full and dynamic I think. The EV are comfy and nice. I seen Zâs Beyerdynamic Dekoni video and was curious if the video holds any validity.
I know you have alot of experience with the 1990 and was curious what pad you recommend. almost like itâs not worth trying to keep the 990s and TYGR since the 1990s can sound like either of them. I do enjoy big soundstage and bass, treble doesnât bother me. Z recommends choice suede for wide bassy intense smooth sound. Choice leather for low-end treble. I also have the Ori pads but havenât tested yet. Iâm curious if youâve experienced the same experience.
Iâm also curious if youâre still running the TYGR filters in your 1990s as well and what I does for the frequency.
yeah, the thing about 1990 is that itâs extremely adaptable. Depends on the signature your looking for⊠I do get the same sound from using suedes on the 1990 it heavily depletes that treble and smooths out the signature while raising that bass by a lot⊠the comfort is no joke either as itâs superb. Leathers yeah, absolutely agreed but only the CHOICE leather⊠sheepskin sounded pretty bad to me. I am personally testing with the new choice suede hybrids which seem to raise all 3 frequencies on the 1990⊠itâs quite something
just depends on what signature im looking for⊠the filter depletes the treble peak and raises the bass by a small margin but it drastically changes the signature if going to like⊠suedes as it can go full on dark sounding together. I have been using the filters to test the new hybrids on it as the peak is a bit much helps alot in my opinion⊠I heavily recommend the filters just as an extra addition⊠they are very cheap and nice to have for the 1990. As far as comparing tygr to the 1990? well, tygr has itâs own signature but itâs not as adaptable⊠itâs just really good for what it is.
Awesome I may check out the choice suede pads for the extra bass, do you think from early impression that the choice suede hybrids may do bass and frequency better then just the regular choice suedes?
very debateable but I would say no since the regular suedes place more emphasize on just the bass while hybrids seem to be amplifying most of the signature to a higher degree. Not even sure how the hybrids will respond on tygr yet⊠havenât tested
If youâre just looking for more bass, an option to look at might be the Elite Hybrid, they boost the low-end bass but donât mess too much with the mids and treble.
Alright, just got in the Choice Hybrids and here are a few things I notice:
TYGR 300 R:
- Darker, richer sounding
- Vocals take a slight step back
- More bass (Sounds great with EDM if you want more âthumpâ to your sound)
- Smoother sounding, without any sharpness in the highs
- Emphasis on strings
- Less of a âzhingâ sound in the highs. (Might be why strings sound better to me)
Again just some quick first impressions with the pads. Listen to them also on the T1 Gen 2 and would said they are decent and I would probably prefer them more on the T1 than the TYGR.
Going to test them on the 1990 and give me thoughts
hmm well vocals were already stepped back on tygr but now more so yeah I am getting that for sureâŠ
I am surprised it has become bassier without distorting to hell⊠very good amount of impact and thump with these pads⊠bit much for me personally.
Extremely smooth sounding on those mids and highs
agreed on less zhing but it does sound actually slightly brighter while remaining warmer on the lows and mids⊠it has this richer presentation with a brighter approach on that treble to my ear⊠honestly itâs responding similar to what I got with the 1990 but the mids lacking a bit throws me off⊠sat here listening for a few hours, treble definitely is brighter than those stock pads it sounds⊠honestly a bit like the 250 ohm 990 now which is damn weird
I honestly donât mind these pads on the tygr⊠they are a good option in my opinion⊠but the one that seems to respond best is absolutely the T1 over there
Yea I didnât leave them on the TYGR⊠it was a bit much for my taste. It was a bit more dialed down on the T1 gen 2. But yea I would say if someone is looking for some pads to tame the highs with a bit more smoother and richer with a bit more extra bass then these will do that.
eh, after using the clears and all that for so long now I just canât go back to recessive mids lol. I love the tygrs but i needs my mids. Still though yeah, agreed⊠these are too much for me but still very nice. plus the comfort on these pads is wonderfulâŠ
btw, does your pads crinkle a bit on your ear? mine have this crinkling sound in the pad when I put them on or press on them.
Yea they do have a crinkle sound if I press in on them and when I put them on my head.
So just listened to these with the 1990⊠hmm⊠I donât think it tames the highs too much on the DT 1990. But does give it more low end and warmer sound. Itâs not drastically dark sound like it was on the TYGR. Kinda interesting⊠Cause I had the Elite Hybrid on them DT 1990 and that brings down the highs a bit more. This is like the hybrids but just a tad less if you âenjoyâ the highs.
Yea I am have really been enjoying my Focal Clears⊠really donât listen to the T1 or TYGR all that often anymore when it comes to music listening.
EDIT: So just tried these on the DT 880 and⊠noooo⊠made the sound stage too narrow. Vocals were still not as forward but it was like I was several rows back from the âstageâ in a boxed room. (Was listening to Chris Jones - Long After Youâre Gone). Was really weird.
Makes the highs a bit more pronounced but Iâm alright with them itâs a good alternative. I still like my suedes more.
Iâm in the same boat though not sure which I prefer more as I have both elex and clear in house. Leaning more towards. Clear⊠thinking I might start selling stuff off soon tygrs included.
Least it sounds great on t1⊠wish I had this pad swap variety on the focalsâŠ
I got that dekoni suede headband too. Itâs really nice
Yea I added the suede headband to the TYGR. It is really nice. Didnât really need it, but I will probably just leave it on as it is softer and I donât really notice it as much on my head.
Interesting you mention that because I have the Elite Hybrids that I just put on my TYGRs:
Yeah I think I would agree with this, although I didnât really hear any sharpness in the highs to begin with and Iâm pretty sensitive to that stuff (DT770 and Dekoni Blues were unlistenable for me).
I like the stock velour pads that came with them for general listening, gaming, etc. but Iâm a bit of a Dekoni homer and I think these pads are so comfortable; it really does emphasize the bass way more. I have to just barely tune the bass down with my Loki+ which is really unusual for me, lol.
I got these as gaming headphones because of the fantastic imaging, but with the pads theyâve become my all-rounders (replaced my 177X GOs).
Hey there, I recently switched from my DT 770âs (80ohm) to the TYGRâs and I love them!
Sadly I miss the comfort of my Dekoni Elite Sheep skin pads (on my 770âs).
Iâm pretty sure theyâll sound awful on the TYGRâs though so now Iâm thinking whether I should get the Elite VeloursâŠ
I donât mind a small change to the sound signature but Iâd like to keep it as close to stock as possible.
Stock padâs arenât an option though, my ears touch the drivers which is annoying AF!
Any thoughts guys?
Thanks
Hmm⊠I have the Elite Velour, but havenât ever needed to actually add them to the TYGR cause they sound great in stock and I think they are comfortable as they are. But I could give it a shot. I would think that it would probably sound fine without change much. Might give them just a tad more soundstage if I had to guess.
Ok so adding them there is a very slight change I am hearing. They are a tad warmer than stock. Tuning doesnât really change much other than that. If that is something you are ok with then that should be fine. But personally I prefer the stock pads on the TYGR still.
That would be highly appreciated ![]()
Such a minor change is perfectly acceptable in my book.
Thanks for trying them out
Did the imaging/sound stage change?
