I think the vocals are slightly a bit more forward being they are a tad warmer.
Sound stage, if it changed then maybe it is slightly less, but not drastically different. Itâs still very good.
Imaging still is still as good as it was before from what I am hearing.
I think it works. Basically you get a bit more comfort and just a bit more warmth is all I am detecting.
Dekoni Elite Fenestrated. Itâs the other option other than the Elite Velours that doesnât drastically change the sound on most beyers. Iâd probably try the velours before I spend more for the fenestrated due to price. Personally, I use fenestrated because I already had an extra pair on hand.
So I got the Velour pads today and I while I like them a lot I wonder whether the fenestrated sheepskin pads might be a little more comfortable.
I got the Elite Sheepskin pads for my 770 and they are godlike if it comes to comfort, however how do the Elite Fenestrated change the sound signature of the Tygrâs?
Whatâs the difference between the Velours / fenestrated?
Thanks guys
Hello. I am considering the Earmen Tr-amp for the Tygr. Is this a good option? Or is Topping stack L30/E30 or maybe one of the iFis better? I read about Schiit too but they are too expensive. Can someone give advice please?
i havenât read the whole thread (yet), so sorry for possibly repeating.
having tested the DT990, DT880 (Black SE) and the Tygr side by side i decided to keep the Tygr for both music and gaming. mostly because, eventhough the DT880 Black SE sounded clear and warm (possibly warmer due to black pads), it still had this thing where the cymbals on most songs sounded just wrong. so it was more fo a sound thing than a fatigue thing for me in terms of treble.
so here is my actual question: did anyone in here, that owns both Tygr and DT880, ever try the Tygr ear pads (including treble dampening inside) on the DT880? seeing how much this change made me love the Tygr, i was wondering, if that âmodâ would turn the DT880 into actually flat more balanced headphones. i loved the mids and bass (at least the bass was no deal breaker) on them but the way treble was lifted made mixes sound weird with cymbals and similar stuff way too far in the foreground.
so in short: do Tygr ear pads with extra treble dampening turn DT880 into flat beyers or will they just make them bad losing their main advantage, airiness, that was possibly only achieved though hyped treble?
Got the new Dekoni Choice Leather Headband in yesterday. The difference in comfort between it and the stock Beyerdynamic headband is incredible. It is so much softer than the Beyer pleather headband, which occasionally created pressure points on my head.
just did a tygr mod for my 990 swapping the pads for tygr pads and tuning foam gotta say I kinda hhate the changes. the pads brought in. the tuning foam did what I needed slightly elevated the subbass killed the mid bass a small amount and took care of most of the treble. the tygr pads kills the mid bass I found and really disliked how they sounded it soundided thinner overall. the tygr pads are different from the 990 v pads they are stiffer and less spongy, they are not quite 770 pads stiff its like an in between it seems like it can flatten out like 990 pads so I might mess with them and intentionally flatten the pads using my 770âs and yoga blocks to see if flatenning the pads improves the sound
The X2HR was going for relatively cheap (there are still about 7 in stock for 100 GBP on Amazon UK) so I thought âwhat the heckâ and got a pair. Iâve seen many ask for comparisons with the TYGR (as did I at one time) so I thought Iâd share my take after a little bit of listening.
The main things I notice quite clearly: the X2HR has a much narrower soundstage with less separation. But in return, bass and vocals are much more forward. There is definitely louder bass which has more grunt. The bass quality seems about the same or possibly lower than that of TYGR but you get a lot more of it.
In terms of treble clarity and overall detail, the TYGR definitely wins. Same for imaging. The fact that things are better separated with the TYGR means itâs easier to pick things out. I can definitely see the TYGR being better for FPS shooters and the like. In fact, I played a few games of Splatoon 2 and found that I could pick out sounds much easier on the TYGR. Heck, I feel like I can pick out sounds easier on the SHP9500 than the X2HR. Edit: I want to emphasise on this a bit more - the X2HR can sound pretty congested at times due to the narrower soundstage and worse separation.
I have mixed feelings about the X2HR overall - I feel like it can be more engaging/intimate due to the smaller soundstage, but I feel so closed in compared to the TYGR. I always hear people say the soundstage on the X2HR is wide, but I certainly donât agree with that. I did find myself headbanging and enjoying some of my songs due to the elevated bass and vocal forwardness, but Iâm not sure itâs worth tolerating the reduction in soundstage.
On the other hand, the the X2HR is relatively inoffensive without any EQ. It has this darker tonality and some unevenness in the treble, but nothing too bad. The TYGR, however, requires some EQ (for my personal preferences) before I feel okay with it.
Probably will spend more time with the X2HR before deciding if I want to return it, but honestly donât know if I can find a use case for it. At least in terms of the things I donât wish to compromise on, the TYGR does pretty much everything better than the X2HR. And in the areas where the TYGR doesnât do as well, I can fix it somewhat with EQ.
@givemebeer Thinking about picking up a pair of the Fenestrated Sheep Skin Pads for the Tygrâs. How do you like them and do they change the sound of them?
That being said, I needed another set of beyer pads and picked up some Elite Velours and tossed them on the TYGR to see the difference and I like them too. I have no idea which set of pads will end up on them in the end because I like both.
@givemebeer so you would say the Fenestrated Sheep Skin Pads are an improvement over the stock pads? Also, how would you say the Elite Velour pads alter the sound signature?
