looks like TFZ has the same company packaging their IEMs or same parent company as BLON but look at this ENgrish on th eTFZ s2 pro
I like that idea with the watch case. Thanks for the audio life hack.
What are these? Another Chi-Fi gem like the Blons or another average? How do they sound?
according to crinacle which I took the pic from just another average v shaped chinese IEM just ok not bad but nothing notable
Well it happened man, cannot resist it anymore for I have decided to order the BLONs. I am curious on how it will do it for me and I guess it is time for me to hear if the sounds from those can like replace my T2s and ZS10 Pros as my only daily driver to use. I hope it will be worth it.
If anythy it will compliment them well. Cause it really does have a pleasant sound
Just got my Blon’s 30mins ago and JESUS CHRIST, I’m completely blown away. Listening with spiral dots and all dat bass is still a bit much, but $24 for this sound signature is just bananas. Was expecting a hard V-shape, but these mids are crazy good for this price range (anyone graph these?). Still waiting for my T4’s and TRN BA5’s from 11.11, but not sure if those are going to wow me in terms of price to performance.
I’m floored. These are great and I’m glad I succumbed to the hype (I disregarded every Blon post I came across). Now I have to go change my pants since I just shat myself listening to these things.
Thanks, I keep forgetting about Crinacle’s graphs!
The sound signature is so different that I wouldn’t think it could replace those too, instead it will give you a more complete sound signature in your IEM collection. Although I do prefer my blons alot of the time now, I actually gave my tin t2s away to a friend since I have my beyerdynamic filling in that hole
The mids son these are something else! It makes a ton of music much more magical and let’s you get into the groove!
Does anyone have both the Tfz t2s and the BLON 03? Kinda got the impression from online reviewers that the TFZ t2 is the “king” of $50 iems, but then the blon seems to be pretty good too. How would you compare them if comparable?
I’m gonna go and try the T2s at a store as well next week, so if anyone has the same question as I do I might just post my findings here
Pretty sure your thisthinking of the wrong t2’s all the hype is for the tin t2.T
he tfz t2 is apparently just a generic iem and nothing to write home about.
Nah I know the tfz from the tins, so I was wondering if anyone had any experience with the tfz ones
Looks like it’s a letter of what type of sound are you looking type deal. If you want Harman target tuning with a bit of a bass hike the Blon are a way to go. If you want a v shape the tfz are the way to go but it has competition like the trn ba5, and the kz zs10 and zsx.
I have both of them, the main differences are mostly in the fit and the overall sound signature.
The T2 are more v-shaped in comparison, with more emphasis on the upper mids/treble area (probably due to the 12mm vs 10mm driver).
I think it’s a good addition to the arsenal, but the only issue I have with them is some massive driver flex, which apparently affects most of the TFZ line even though they are all vented.
I would say that they aren’t really that similar, but if you were to compare them specifically to the BLONs, I would rather take the BL-03 over the T2.
So just got mine had my first listen, and I gotta say one word…
Awesome
The stock cable isn’t great but I don’t hate it either. I’ll probably get a new one but I wish there was a Bluetooth cable for them, that would be them so great for working out. (I have a FIO BTR 3 but i’m still hoping to find a Bluetooth cable to reduce the cables )
The Blon-03 have some serious kick to them and just an overall very enjoyable listening experience and I agree with previous mentions of the Tin T2. The T2’s are great but the are more “smooth and relax” while the Blon is a more “bust some heads” kind of IEM.
I ordered the KZ Bluetooth Module 5.0 for my Blon’s. The “C Pin” is the QDC cable, but you’ll have to shave down the pin connector housing on the IEM itself to get the cable to fit. Unfortunately it’s currently en route so I can’t properly assess it’s performance, but at least a bluetooth cable exists on the cheap.
Well if they are any good i’d really love to hear about it.
So what size dekoni tips do people recommend for the 03, the 3mm or the 4.9mm size?
