The 4.9mm nozzle sized tips will fit.
I found the 4.6mm stay better on the BLON-03, the 4.9mm come off in my ear.
Just a note, since everyone’s been having issues with the blon’s cable & fit.
After swapping out the cables & tips, I’ve been using these to sleep in, and I found they’ve been actually the most comfortable IEM’s to sleep in since they have no sharp edges and are so low profile.
Indeed, the highs are really toned down and the airyness is great to chill out sleep
I know I could look through the thread but it is almost at the 300s so it’ll be a little difficult. With the current deals going on, would y’all rec the ZS10s or the Blons? ZS10 is 42$ and the Blon is 36$ i believe
I think with the deals going on, at linsoul there is a deal with the blon and a cable and some nice tips that I think is worth it. Personally I like the blon more than the zs10 pro. I would say if you like a more aggressive sound the zs10 pro would be for you, but otherwise the blons are pretty good imo
Finally got my hands on the OPPOTY, it lived up to its hype, got P1, OH10, T2 and it’s up there with all of them. I favor the P1 and T2 more though but its mostly the taste. Oddly the stock cable and stock tips were the only thing that worked for me, couldn’t get any other cable to fit properly, even TFZ cable had sone space between… Any suggestions on a proper QDC cable as i tried a straight 2pin and it looked ridiculous.
I think the QDC cables need to be modded or the connector on the IEM, my understanding is there is issues with circle square corner issues, outside of that I’m not aware of anything else being a problem.
As in problem, no, they work fine but the looks and the comfort over ear style goes out the window for me…
That additional plastic block and 2 pin connector length is a bit uncomfortable for a kid or a woman with small ears… Sadly Gifting it with stock cables but the search continues for a gud cable
Not too sure about cost and shipping? but https://www.lazada.com.ph/products/35mm-2pin-copper-silver-mixed-plated-upgrade-cable-wire-for-blon-bl-03-bl03-i464582316-s1204674039.html
Ordered this cable from drop a while back and just arrived today. Works really nice with my phone paired with the Blon 03. Might look into an mmcx fkr the tin t4 as well.
How much did it cost? Is the quality good?
I’ve been looking for a good reliable mmcx bluetooth cable for a friend
These were $34 on Drop when I ordered them. It sounds great paired with my phone. No complaints. The wireless convenience is very nice. Paired quickly and easily.
ooooooh nice price! Thnx alot!
This iem is so versatile as a small ear hole person I really appreciate them fitting the mh 755 tips
In the comments of Porta.Fi’s review there are a couple of people mentioning that the silver and gunmetal BL-03s are differently tuned. The silver tuned towards detail and clarity while the gunmetal towards bass.
Very surprised about this, if true. Can anyone confirm?
I have the gunmetal and they are indeed bassy and warm and lacking detail and clarity.
