Budget bassy headphones under 100$?
the k240 definitely appreciate a little more power than most around it’s price range
Yeah that would be pretty great, I haven’t heard it though
You gave me the nudge to buy these in my initial post… thank you good sir
no problem I love it when I see another k240 fan
better post some pictures once it’s done!
mh 751 have booming bass ? can play music
or takstar pro 82 what a difference? which one have booming bass
I wouldnt say booming bass but they’re pretty good for the price.
@ammardien I would actually recommend the Creative Aurvana Live if you want something with boomier bass than 751 or Takstar.
personally like the retros with brainwaves pads but that does put them at about 50 with current prices. which is exactly the same price as the CALs in the US currently. Really big booming bass enjoyable for bassy hiphop and edm. I’ve not heard the cals myself so not sure how they stack up to eachother
m40x have booming bass ?
m40x or yamaha mt5
Pro 82’s with the vents wide open is definitely boomy bass (pretty sloppy though)… two papers suggested the retro’s and I agree with the brainwavs xl pads they have cleaner boomy bass … nicest cleanest bass its Sorens suggestion the cal (a little less boomy)
Those have decent bass, but not anywhere near the Creative Aurvana Live.
In terms of quantity I think they win but quality goes to the cal
Yeah but it isn’t necessarily less by any large margin, plus Zeos said the bass gets distorted with the bass ports all the way on the 82s.
can you recommend for me headphone good serious gaming and have booming bass
what’s your budget and do you have an amp?
i don want amp … budget around 120 usd
for gaming are you looking for hearing footsteps and sounds accurately for competitive or are you wanting detail for sound effects like explosions in a more casual or single player experience?
for competitive and bass booming
