Yeah I always thought that they are what other IEMās are judged by ie a bench mark?
They certainly have been that for me. I got inspired this morning and wrote up quite the lengthy review of Solaris that included comparisons to OG Andromeda and a few other IEMs.
OG?
10 characters
Original Green(sta).
There are more than half a dozen variants that share the name āAndomedaā but have various color changes and tweaks to the tuning. In fact, even the original green Andros have a couple generations (no idea how much the sound has changed, but I believe there were minor changes to the cable and leather pouch that they come with).
Anyway, āOGā refers to the basic model with original tuning.
The Original version
Just a quick question if I mayā¦have you tried the Solarisās super Litz cable on the Androās if so did it make and audio improvements over the std Litz?
Picked them up today and mint they are plus itās always nice when things come with the warranty card and original receipt ![]()
Iām not one to ascribe sonic differences to cables unless itās a cable doing something wrong (e.g., loose connection). Iāve never been able to experience [repeatable] differences from a cable swap that I couldnāt explain away with another more plausible explanation. For example, I find that many of my IEMs sound better balanced, but I believe the reason for that is the balanced paths in my source chains are likely more optimized, the total lack of crosstalk may bring out a smidge more detail refinement, or even differences in output impedance could change damping factor. If the balanced cables are contributing anything itās mixed up with the other variables that change.
That said, I donāt shy away from nice cables for nice IEMs, and I love the Campfire / ALO cables. Theyāre comfortable, well-built, and look really sharp. Some time ago ALO had a clearance sale on them and I picked up a couple extra litz and pure silver litz cables at a great discount. The super litz comes standard with Solaris, but I havenāt bothered moving it around to other IEMs.
Theyāre here!!! Canāt wait to hear your thoughts! What are you gonna run them through? Canāt wait to hear your thoughts!
Hey buddy Iāll be using my iFi Micro iDSD I gave them a few hours use last night mostly to experiment with tips (Iām lucky in that department as most tips seem to fit me a ok) to see which work best on them. Spinfitās seem good so far but Iāve got some Spiral dots on order. Iāll give then a week or so before I give my thoughts but theyāre already bringing a smile to my face
I used spiral dots on mine. They seemed to fill out the bass without changing the SQ. Anything but foams
The stock Campfire ones are not bad. I slightly prefer Spiral Dots, but I also got these for my Andro Golds, and they work great:
I mixed and matched black-red and black-blue for the Andro Golds. For OG I might go all-black for left and black-green for right.
Got some of these on order tooā¦
Ah okay! I think youāll be smiling for the next week before and after the new tip order! Theyāre a special pair, for sure
Well, well, well what a totally mesmerising set canāt really add to all the numerous reviews and comments aboveā¦
Ok just my 2 pence worth yep the treble is stellar, like nothing iāve heard on an IEM, it has space, itās extended and shimmering, absolutely stunningā¦Mids are a tad laid back but just a tad so vocals still have their own space and arenāt too receded, bass is fast, accurate and textured but could dig deeper?..I find the timbre to be pretty natural and unforced, instruments seem to do what they do and sound like they should. Sound stage is okā¦but imagining is as well up there.
Any negatives?..yep for me that memory wire in the cable is a pain and yes I tried a couple of others I had, but maybe as one of our members stated the set has such low impedance that any cable can fuck with the soundā¦yeah it really really does?? my FiiO FH7 cable did them no favours at allā¦so iām on a look out for a pure silver 3.5mm mmcx cable lolā¦so all in all the Best $780 iāve spent so far on my IEM journey
If you are good with a scalpel that can be fixed lol
Can you get the end thatās in the mmcx plug moulding out it looks hooked over?
So I havenāt done this with the Andros, but I just cut the shrink off and then took wire cutters and snipped the memory wire at the mmcx molding as best as I could. Although I canāt recommend this because if you mess up you might have a broken cable on your hands
Itās not heat shrink itās part of the solid plug all be see-through.
Or you could just PM me and I can make you a cable
